Changing Engine Mounts
Old Jan 7, 2007 | 08:02 PM
Speed Racer's Avatar
Car: '87 Camaro Sport Coupe
Engine: 383
Axle/Gears: Ford 9, Detroit Locker, 35 sp, 4.11
Has anyone ever changed the motor mounts WITHOUT removing the lower A-arms? If so, then you know how dang near impossible that is. Well, after a day of busted knuckles and cuss words, I finally did it. ...just wanted to brag.
Old Jan 7, 2007 | 09:30 PM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
It's easy, Why did you put your bolts in upside down?
Old Jan 8, 2007 | 06:52 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I removed the bolt out of the the control arm bushing that is closest to the radiator and presto
after you are done you just jack the control arm back into place and reinstall the bolt
Old Jan 8, 2007 | 11:29 AM
Engine: 383
It might be easy if you have a rhesus monkey as a helper! I put them in upside down cuz there was no way to get the nut started that deep inside the subframe. However, I was able to hold the bolt head in an extra long box end wrench with some black tape. Then I could push it up thru the holes and start the nuts.
Old Jan 8, 2007 | 01:54 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I did mine the same way - much easier than fighting that nut. Won't matter either way. Some claim that the nut might come loose, the bolt would fall out, and you'd be screwed - but if the nut comes loose any, you should feel the vibrations LONG before anything falls out anywhere.
Old Jan 8, 2007 | 01:59 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I've done it before without taking off the A-Arms... I also did it without removing the engine (unbolted it obviously). It is a major pain, but once you figure out how to get a wrench in the right spot, its not so bad... I used a magnet to hold the nut (attached to the flat side of the nut, then I used a wrench once it was started)..
Terrell351
Jun 13, 2021 01:13 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
