Anyone ever heard this?
Old Jan 10, 2007 | 09:34 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Have about 2000 miles on this engine.started it this morning and i heard a fairly loud tap followed by a slightly quieter tap tap tap.I shut her down and cranked it again and it was gone,ran fine.do i need to adjust my valves?drove fine the rest of the day.It was a 30 degree morning,can a valve or lifter freeze up on a cold morning or do yall think maybe the oil jusrt hadnt got up there yet on a cold morning?Any ideas?Thanks.
Old Jan 10, 2007 | 11:59 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
what type/weight oil & oil filter are you using?
a lifter could have bled down, its not common but does happen.
Old Jan 11, 2007 | 12:38 AM
Cam-aro's Avatar
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
Sounds like a lifter was clickin, Haha, all too familiar thing to me, just had to tighten mine the other day after putting in the new heads.
Just pop off the valve covers and take a ratchet and slowly tighten'em down to point right before car starts to sound like it's missin.
Old Jan 11, 2007 | 01:27 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
sounds like a cold start, the oul is really thick in that weather so it takes longer to get to the top of the heads thru the push rods and the engine has to work a little longer to accomplish this.
Old Jan 11, 2007 | 08:41 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
IT DIDNT DO IT TODAY AND SEEMS TO BE RUNNING FINE.LIFTER BLEEDING DOWN?Not familiar with that,this is my first engine build.I do have some thick 20/w50 castrol in it which would be like mollasses on a freezing morning.Not sure what part number my filter is but i know its a delco.Thanks! oh i did brake it in with straight 30 weight,Just changed it to the 20w/50.
Old Jan 11, 2007 | 09:50 PM
DENN_SHAH's Avatar
i would recommend going to 10W30.
i used to run 20w50 in my 350 carbed motor, i started getting cold start up rod knock when i got around 2000 on that motor. i was mad, a brand new motor knocking, & it was my fault, i had to replace the rods & mains to stop the knock.
the thick oil takes too long to get to everything on cold startup, even in warm weather unless its in the 90s or hotter.
i now use 10w30 year round & have around 180,000+ miles on the motor in my car now & have no problems with cold startup rod knock & have good oil pressure.
Old Jan 11, 2007 | 09:58 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
thanks guys. i`ll run through the valves and change the oil.Hopefully i`ve done no damage.
Old Jan 11, 2007 | 10:29 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
And who taught you that???
Loosen the rocker while the motor is running until you hear it tapping. Tighten till the slight tapping sounds and they apply another 1/4 - 1/2 turn. Thats it.
Old Jan 14, 2007 | 01:40 PM
Pat Hall's Avatar
I was thinking the same thing when I read that!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Jan 10, 2020 08:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mcbitchman
Sep 29, 2015 12:32 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
