Starter compatability auto v.s. stick
Old Jan 12, 2007 | 12:24 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Alright, i know the starters are different in my 89 RS, auto and t5 are different, anyone know why or what the difference, i want to but the cheaper starter which is the automatic part #, the t5 starter is 25$ more, anyone who can shed some light is the man.
Old Jan 12, 2007 | 09:52 AM
The nose on the T-5 starter is smaller.
Either one will work on an auto car; but the auto starter won't fit inside the T-5 bell housing.
You'll find that actually, ALOT of the starters that you buy as the "auto" part #, actually have new nosepiece castings that are identical to the T-5 one. That way the casting mfr only has to supply one part # of casting.
Then the parts store and everybody else in the supply chain gets an extra spiff 20% of the time, when they get to hit up the uninformed T-5 owner for some extra change for the differently listed part.
Get the parts store guy to bring you one of each, and look at them. If the nosepieces are the same, then the rest of them is also the same; and just buy the cheaper one.
Old Jan 12, 2007 | 09:59 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My 88 was an auto and I put in a T5 and used the same starter (didn't even have to take it when we swapped tranny's).
I may have the one that is compatible with both tranny's though. Mine is quite large too.
Old Jan 12, 2007 | 12:34 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Thanks, i have a auto starter i am going to try out, ill let you guys know what it does.
bbsr72
Sep 27, 2015 05:55 AM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
Formula_88AE
Sep 3, 2015 01:47 PM
