engine keeps going after shutoff?
Old Jan 16, 2007 | 09:39 PM
steeljab's Avatar
Car: 87' Camaro
Engine: 305 carbed
somtimes my car (87 camaro 305tbi 4bbl lg4) when i turn the key to turn her off it acts like its off(gauges quit, stereo turns off etc etc) but the engine sounds like some of the pistons are still going "boom boom boom" and it shakes a bit...first time it did this is quit after aobut 3-5 seconds, but today(second time) it kept going for about 15 so i turned the key real quick and it started right up..shut it off and it "died" just fine.
any ideas? could it be spark plugs? or should i try running on the lowest fuel instead of high grade?
thanks,
Christopher
Old Jan 16, 2007 | 09:46 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
it could be carbon built up in the engine it gives the engine "Hot Spots" where it gets so hot in these spots that it continues to burn the fuel evan after there is no spark.
run a fuel treatment through it and replace the plugs. that should clear it up (well it did for my car)
umm 305TBI LG4?????
Old Jan 16, 2007 | 09:53 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Have you thrown a timing light on it? If you throw the cheaper gas in it im sure it will probably just get worse. What kind of idle speed are you running at?
Old Jan 16, 2007 | 09:54 PM
steeljab's Avatar
Car: 87' Camaro
Engine: 305 carbed
thanks. ...I *think* so or is that totally contradictory (XD just learning aobut cars period really(including camaros)) person i bought it from called it a 1987 Camaro "RS" but its got a 8cyl in it, which i believe to be the 305 and according to the VIN its an lg4 (which i thought was 305tbi..XD had her four days to figure out what she is on no sleep) so anyways...>.<
idle is 1500 cold(choke on) about 950 or so warmed up. no i havn't done anything to it, just bought her stock(cept hood is a 3in cowl).
Old Jan 16, 2007 | 10:01 PM
VenomX-87's Avatar
yeah it would be a 305 LG4
TBI = Throttle Body Injection.
Old Jan 16, 2007 | 10:04 PM
steeljab's Avatar
Car: 87' Camaro
Engine: 305 carbed
my bad :P at least i didn't think it only had 6 cyl's atfer owning it 3 years (i figured that out in 5 minutes lol)
Old Jan 16, 2007 | 10:09 PM
izcain's Avatar
Engine: 584
well when replacing the plugs and whatnot I would definitly check timing. Might be a run on condition which can be caused from timing being off. It could be carbon like what venom has been saying as well.
Old Jan 16, 2007 | 10:14 PM
VenomX-87's Avatar
yeah im only learning to, this forum is gret for getting tips and help with these cars.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
