engine wiring... (cutting)
Old Jan 21, 2007 | 12:54 PM
sLoW'n'StEaDy's Avatar
OK, to start its an '88 trans am. I am converting it to carb and wont be keeping anything really but the lights, wipers and power windows. The firewall is getting "smoothed" all the A/C and heat stuff is gone along with all the vent and other crap from behind the dash. I am putting in a TT383 with a TH400 trans. So will i be able to use any of the stock gauges? If possible i want to use all my stock gauges and just add a pod any additional gauges, but im not sure if that will work with my setup.
Also as far as all the other stuff i wont need goes, can i just fallow the wires bakc to the main bulkhead connection that goes to the ECM and just remove them completely? (example; A/C stuff, TBI stuff, and other senseors and such i wont be using) Or do you think it would be easier to just use all aftermarket gauges? My main thing is i want to keep the headligths, taillights, turn signals etc... all like they are stock
Old Jan 22, 2007 | 06:37 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Engine oil pressure and temp will work if you use the original engine sending units on the new engine. The alternator charge/volts won't change if you use the original alternator. You can hook up the tach wire and the stock tach will work unless you are using a MSD system. Leave the ECM in place (it doesn't weigh that much). You can kill 2 birds with one stone and disconnect the "check engine" light at the ECM and use it for a rev limit/shift light. Don't forget to hook up the ground wires to the back side of the D/S cylinder head.
The hard part is figuring what to do with the in-tank fuel pump. I would recommend using a "bypass regulator" and rewiring the F/P relay to run at key on.
Old Jan 22, 2007 | 11:29 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Originally Posted by Supervisor42
...The hard part is figuring what to do with the in-tank fuel pump. I would recommend using a "bypass regulator" and rewiring the F/P relay to run at key on.
From the info provided I can't tell if it was originally a TBI, or a MPFI engine.
If TBI unit (15-20psi) would work with the proper bypass-regulator.
A MPFI fuel pump would have to bypass 30-35psi which is the reverse of what it was designed to do.
Old Jan 22, 2007 | 11:38 AM
originaly TBI. I am going to use a 3 port fuel pressure regulator to drop the fuel pressure down...
Old Jan 22, 2007 | 05:11 PM
Engine: 350 4BBL
The bypass regulators are a little pricey but worth it. I've been using JEG's #793-30-900 on my formerly TPI car with a Q-jet with great success.
All the other (non-bypass) regulators won't work so don't try to cheap-out.
Terrell351
Jun 13, 2021 01:13 PM
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
