hmm what goes here?
Old Jan 23, 2007 | 02:14 AM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
hmm what goes here?
hey just wondering what are the 2 threaded holes on the block just in from the mechanicle fuel pump? i have no screws in them and one is leaking oil, duno if they just fell out over time or if i took them out and just forgot to put them back in.
Old Jan 23, 2007 | 05:48 AM
From 55 to 57 in cars, and well up into the 60s in trucks, they were the motor mount location. Same for the matching pair on the other side.
Since the late 60s, they have been the smog pump bracket mount location.
The upper one goes RIGHT DIRECTLY INTO the passage that the fuel pump drive rod passes through. That's why it leaks oil. Put a SHORT bolt in it, with a drop of silicone on the threads.
That's probably the single most common new-motor "mystery" oil leak; it leaks while racing or accelerating or even just cruising, or otherwise at high RPMs, but not at idle. It gets oil all over the lower right side of the engine bay, the underside of the headers on that side, on top of the mech fuel pump, and all down the side of the block. The oil drips off the block and gets slung everywhere as a fine mist by the crank damper.
Another time that it appears, especially on this BBS these days with the kind of people that alot of these cars have passed into the ownership of, is when people have just hacked off their smog pump, usually because they think they're "cleaning up the engine bay". What a crock. They take off the bracket, and suddenly there's this leak.
It's AMAZING how many people will show up here with that problem, and INSIST that THEIR bolt hole is different from everybody else's, that that's not where THEIR leak is. They'll argue with the fact for days on end. BS.
Old Jan 23, 2007 | 05:52 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I don't recall that there's anything there (someone please correct me if I'm wrong). A fuel pump replacement trick is to thread a longer bolt into the upper hole to hold the fuel pump push rod in place--much easier than the grease method.
JamesC
Old Jan 23, 2007 | 03:01 PM
VenomX-87's Avatar
yeah mine dose it at high RPMs coz every time i open the bonnit every thing on the right side is soaked, so i got ma gf to sit in the cab and rev it to 3,500 a fue times (me looking real close to the engine) i got coverd in oil
Old Jan 23, 2007 | 06:11 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Ahh, the Infamous "Sofakingom Leak"
Old Jan 23, 2007 | 06:35 PM
JamesC's Avatar
Yeah, I'm sure that boy's got leak in his lower block somewhere
JamesC
Old Jan 23, 2007 | 08:06 PM
Old Jan 23, 2007 | 08:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
slightly unrelated, but i have a fuuny story about that hole. i swapped in a holley pump a while back and used a bolt to hold the pump pushrod in place while i did the swap. i got everything all finished and forgot to swap out the long bolt for a short one. started right up, let it run for a few seconds and backed out of the garage just in time for the car so starve out and die. i was like "WTF ? is the new bad, damnit" so i got all bummed out, got a friend to help push it back into the garage and went to start taking the pump off when i noticed the bolt. i felt like an idiot.
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Scania
Apr 20, 2002 06:04 AM
Z28Freakboy
Mar 13, 2002 02:16 PM
DrekkenX
Jan 22, 2002 09:49 PM
mudaholic
Pacific Northwest Region
Jan 19, 2002 06:09 PM
