head help for roller cam
Old Jan 25, 2007 | 10:11 PM
krogmister16's Avatar
Car: 88 firebird formula
Engine: 305 tpi
Transmission: 700r4 with shift kit
Axle/Gears: 3.73 with eaton locking diff
i just bought a roller cam and lifters for my 355. can i put dart iron eagle heads on it if its a roller? or would i have to buy the new style heads? thanks seth
Old Jan 25, 2007 | 11:50 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
first off, roller is only the cam and lifters.. you can put any sbc head on any sbc regardless of the cam style.. you should get the recommended springs for the cam though.. or if the recommended springs are close to the ones you have now(preferably stiffer), then its all good.. if you do reuse the springs, make sure it can handle the lift.. and check your pushrod length, you might need different length ones..
junkcltr
Aug 2, 2019 11:12 PM
camaro71633
Sep 1, 2015 10:24 AM
bdads
Aug 24, 2015 06:01 PM
anesthes
Aug 8, 2015 09:37 PM
