Newbie with small block ?
I'm new to the board, and am looking into the purchase of a friends '83 Z28 project car. The first question is how do I tell if the engine is a 383? I decoded the casting #s, and I know it's a 350 with 4 bolt mains. Is there an easy way to tell the stroke without dissassembling it?
Thanks, mike
Thanks, mike
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Not really...at least not that I know of.
You could pull one of the heads off and check the bore of the cylinders. A 350 bored .030 (total of 4.030") combined with a 3.75" stroke is a 383...but a 350 bored .030 (using stock stroke of 3.48") is a 355...so you could know if he's got a 355 and could probably assume it's a 383...but I'm sure you know what assume means...
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
yes and no the heads need to be off so you could meassure the swept volume of a cylinder but the bottom end can be complete
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I doubt you'll find a dial indicator with 3.75" of travel in it. A ruler will work, or a caliper.
It may be possible by the balancer/dampener and flexplate if he used an externally balanced kit. If a portion of the outter ring is scalloped or cut out, then it's possible to have a 383/400 crank. If smooth all the way around, it still maybe, if internally balanced. Since this is your "friend", any reason to doubt him?
Car: 91 RS
Engine: 350 vortec
Car: 1982 Trans-Am
haha, yea, $300.... I'd rather use a $25 digital caliper...
Car: 91 RS
Engine: 350 vortec
yeah i just like a tool i will use once in my life but i wouldnt order it from the internet it would have to be an impulse buy
New2Chevy
Sep 28, 2015 12:35 AM
84 TA NV
Sep 6, 2015 08:02 PM
