stalling and bad acceleration problem
Old Jan 27, 2007 | 11:07 AM
BRYAN BUSH's Avatar
Car: 91 Z28
Transmission: BORG-WARNER T-5
i was driving about 30 mph when my car started to sound slugish then it died on me.i started it back up and got it home by feathering the gas pedal.it happens at slow speeds..i dont know about higher speeds.when i got it home i tried to start it up but it wouldnt fire.i tried it about 2 hours later and it started right up.my father in law said since its been cold and i dont drive it much i needed to put some heet in it and see if that helps.i did but it still does it.i took to take my daughter to school and it died on the road.i went down to start it a couple of hours later to get it home and it would crank but not start.i tried later a couple more times and no start so i checked for spark and was getting any.checked it out and the distributor had cracks in it and was real rusty,so i replaced it,the module,cap,rotor.i put everything back correctly and then fired it up and it ran like a champ.i drove it for about 45 mins and everything was fine.then i took it out to take her to school again and warmed it up..went back out to take her and it was not running.i tried to fire it up and it would just crank.went out an hour later and it fired right up.i took it out and it drove good for 5 minutes and then started to accelerate poorly in first and second gear and was really sluggish. so what does it sound like? could a dying fuel pump do it? thanks it is a 91 z 305 with 67000 miles
forgot to mention..no codes
Last edited by BRYAN BUSH; Jan 27, 2007 at 11:09 AM. Reason: Automerged Doublepost
Old Jan 27, 2007 | 11:56 AM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Yes a pump could do it, If you have a fuel pressure gauge test it with the key on and while idling and if u cant repeat the problem tape the gauge to the windsheild and wait till it craps on you, Take a peak and see if its because the fuel pressure is dieing out. ( primed i believe its supposed to be 43 psi, someone will chime in on the exact amount im sure)
It semi sounds like the module, but u have replaced that. just in case if u can get it occur and just crank, check spark again it may just be a defective module once again /shrug.
Good luck!
Old Jan 28, 2007 | 06:46 AM
BRYAN BUSH's Avatar
Car: 91 Z28
ill check it for spark when it does it again.if its getting spark then i check the fuel pump thanks for the info
Old Jan 28, 2007 | 05:15 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
When my 2.8L did that (and it happened so infrequently it was SOOO annoying.) It would just suddenly bog down like it ran out of gas, not start for like an hour afterwards.
My problem was the fuel pump relay. Well not the relay itself, but the connector. It was making poor contact with the relay and whenever it felt like it would crap out, give it time and it worked again.
I went to the yard and got a few of the best looking connectors there, and soldered/heat shrank them back up. Hasn't happened in more than a year now.
Old Jan 28, 2007 | 09:54 PM
mark wells's Avatar
Car: 85 Trans Am
Engine: 383 ci
Axle/Gears: posi 342
I was having the same problem, turn ignition off (after it dies) wait 15 seconds and turn ignition to on. You should hear the fuel pump prime. If not you got trouble. My problem was with my MSD 6AL. But I know another member that had the same problem until he installed an MSD 6AL. Dont run out and purchase or tear it off if you have one I am just stating a possibility.
Old Feb 5, 2007 | 04:58 PM
BRYAN BUSH's Avatar
Car: 91 Z28
the ignition module and pick up coil that came on the new distibutor was not tight so it does not stall anymore but when the idle fluctuates.it idles at 900 but every 30 seconds or so it goes down to 500 to 600 and its just kinda rough over all....had it looked at and was told it has a hole in the cat and has a intake manifold gasket leaking.... does that see like that would take care of the problem? thanks
Old Feb 5, 2007 | 05:14 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
the cat shouldnt affect idle unless it is clogged but maybe the manifold gasket depending on where and how it is leaking
Old Feb 5, 2007 | 06:04 PM
creepz28's Avatar
hmm, my camaro had a similar problem, but it died once and stopped starting. i found out 5/8 injectors were bad. hope yours isnt not as serious as that, but it may be possible. my mechanic is charging me 1200 to fix it, and replace all 8 injectors
Old Feb 5, 2007 | 06:05 PM
BRYAN BUSH's Avatar
Car: 91 Z28
i let it warm up for about 30 mins then i took it and drove it and the accleration was not so hot.it just didnt have that throaty sound like it used to its like you can hear it pick up speed?...dont know how to descibe that sound it makes when acceleration through the gears?
Old Feb 21, 2007 | 05:03 PM
BRYAN BUSH's Avatar
Car: 91 Z28
anymore help? i start it 10 mins it dies checked for spark no spark..it has new car-rotor-coil-distributor-module-plugs-wires- had module tester and it was fine why no spark after it warms up for 10 mins but will restart an hour later? thanks
Old Feb 22, 2007 | 03:51 PM
Car: 91 RS
Engine: 350 vortec
replace the module some will test good when cold and not function when warm
Glowsock
Jul 24, 2025 03:15 PM
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
