edelbrock - rpm air gap and performer rpm
Old Jan 29, 2007 | 12:22 PM
kaptinkafeen's Avatar
I'm afraid to ask , but after searching I couldn't find the exact answer
I have a '91 Z28
stock hood,
holley street avenger
edelbrock drop down(base) air filter assembly
will either the edelbrock rpm air gap and or the performer rpm fit underneath the hood with no clearance issues?
Yes or No? - or depends on engine mounts?
Thanks a bunch
Andrew
Old Jan 29, 2007 | 01:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
FWIW, they both are the same height deck-to-carb base.
They will fit with a drop base air cleaner.
Poly engine mounts typically hold the engine higher than sagged stock rubber mounts. But they are the same as replacement rubber mounts.
Old Jan 29, 2007 | 01:40 PM
No matter how much I search, getting direct answers like the one you gave (and give) are great!
-Andrew
Old Jan 29, 2007 | 03:50 PM
five7kid's Avatar
Don't use the Street Avenger!
How's that for direct?
Get a double pumper. Much better carb for performance, no different for daily driving (after you add an electric choke).
If you really, really want vacuum secondaries, just get a universal of the same CFM, add a 4150 conversion kit and a Quick Fuel adjustable secondary diaphragm housing, and be done with it.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
TreDeClaw
Jun 22, 2021 08:21 PM
beastin91rs
Oct 9, 2015 07:38 AM
Dialed_In
Aug 20, 2015 01:45 PM
TreDeClaw
Aug 14, 2015 06:58 PM
