305 tbi to 305 tpi
Old Jan 29, 2007 | 07:20 PM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
305 tbi to 305 tpi
Whats the difference in the 2 and how can u change a tbi to a tpi?
Old Jan 29, 2007 | 07:29 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
TPI is a multi port fuel injection, thats the biggest difference. In my opinion, it wouldnt be worth it. Have to have new intake manifold, tpi setup, i think a different fuel pump, the new wiring harness and computer. And im sure there some other things that im missing but thats the majority
Old Jan 29, 2007 | 08:25 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
if you have tbi stick with it if you have tpi stick with it...each has its own drawbacks as tpi sorta falls on its face past 4500 but makes more torque than tbi but i notice my tbi is pulling past 5500 while my bros tpi is in need of a shift
Old Jan 29, 2007 | 08:39 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
With all the time and money it would take, its just not worth it, it may be a little faster but not enough to justify all the work and money. Spend the money on other modifications to your TBI and youll see better results.
Old Jan 29, 2007 | 08:45 PM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
...or just bypass all the crap and get a Holley Stealth Ram setup...it's kinda like TPI but with all the shortcomings fixed...it will make that 305 feel like a BEAST!
it's about $2,200 or so last time i checked but thats for EVERYTHING...ECU, wiring, intake, injectors, EVERYTHING...it is DEFINITELY worth it!
Josh
Old Jan 29, 2007 | 09:28 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Josh
That would be bad ***. You talking bout the one that comes with the software for a laptop??
Old Jan 29, 2007 | 09:39 PM
Phatfiddler's Avatar
^and all of that is a waste with the stock LO3 heads. This is coming from someone who owns a LO3, and has swapped the intake several times.
Old Jan 29, 2007 | 09:41 PM
you would still see a performance increase...you could upgrade heads later...some guys have to do it one piece at a time...
Josh
Glowsock
Jul 24, 2025 03:15 PM
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
92purpz28
Aug 11, 2015 02:30 PM
