MSD Ingnition
Old Jan 30, 2007 | 10:26 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
MSD Ingnition
What are the benifits of putting the MSD Inginition in my car? Right now my car runs good so how can this improve the operation of my car? I see a lot of people have them. Should I change anything else at the same time?
Old Jan 30, 2007 | 10:34 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You probably wouldn't see any benefit.
Old Jan 30, 2007 | 11:47 AM
Axle/Gears: Posi
Why not?
Old Jan 30, 2007 | 01:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Unless you're running a modified engine at higher cylinder pressures or higher speeds where the stock ignition system has trouble igniting the mixture, there's no benefit to be had from an upgraded ignition.
Old Jan 30, 2007 | 03:21 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I've got a Crane Fireball multi-spark ignition... Big waste of money... It has a rev-limiter, but so does the ECM... No difference in performance if I unplug it or otherwise... If there is a difference, you definately won't notice it... 99% chance that the money could be spent better elsewhere..
The factory ignition on these cars is pretty damn good...
Old Feb 19, 2007 | 06:13 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Reading this post amazed me!!
When I first installed an MSD 6A box on my '81 Elcamino with a dead stock 3.8L V6, I barely noticed a difference in horse power. But there was about a 2-3 MPG gain, and when it came time for smog, it passed cleaner than before. Then I intstalled that same box on my '82 T/A, with a stock LG4 and there I did notice a seat of the pants difference as well as the increase in miliage. I built a 350 for the T/A, but didn't put it back on the street. I installed that 350 into my '73 Nova (with the same MSD box), and that thing pulls to 7000 rpms with out hesitation. I recently bought another MSD 6A and the Blaster coil, installed them both into my Formula, and I really didn't believe the power difference. Yeah, I do have a built 383, but at all pedal positions, as well as higher rpms, there is a huge power increase. I'm still getting the tuning down, (I recently had to replace the relays for the MAF) but the MSD is definately worth getting.
As for the Crane Fireball, yeah, it is a waste of money. They just don't have the output that the MSD does.
Old Feb 19, 2007 | 06:15 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Noticing an improvement after installing an aftermarket ignition on a stock engine is a sign that your stock components were worn out. Replacing them with new stock components would have produced the same results.
Old Feb 19, 2007 | 08:50 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
a little off topic, but where to mount on a car w/ ac?
thanks,
mike
Old Feb 20, 2007 | 07:10 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
I'd mount it under the dash because it will look like **** wherever you put it under the hood.
I have to agree with whats been posted as to the benefits on a stock car. Ignition boxes are good where a stand alone ignition system is needed. Like on a carb conversion where all the stock wiring, ECM, etc. is removed. Mount the box, wire 12v to it and plug in the distributor. Doens't get easier. Putting it on your car would be a waste.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
sreZ28
Oct 22, 2015 08:21 AM
meeklay812
Oct 1, 2015 03:46 PM
86CamaroDan
Sep 29, 2015 10:08 PM
