Old Feb 3, 2007 | 04:12 AM
motormouth19's Avatar
simple question ...what is the diff. in a pontiac455 ,buick455 ,and olds455
Old Feb 3, 2007 | 07:59 AM
Redbird87's Avatar
Engine: 355
RE: 455----------------- simple answer...most everything
Old Feb 3, 2007 | 08:15 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
As Redbird stated everything internal and external.Put another way they are as different from each other as the BBC 454 is from them.The only things they would share would be a Rochester carb and they use the same bell housing bolt pattern(which is different from Chevrolet).
Old Feb 3, 2007 | 11:41 AM
ok thanks ...let me ask this what are the pros and cons of the bop 455s. because i got a buddy that has an old 455 for farly cheapr ,would this be a plus or a pain in the neck....
Old Feb 3, 2007 | 12:52 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Pros - you can buy it from him fairly cheap. It's a fair bit of cubes, more than the 305 in there now eh? That'll be an easy torque addon. Wow factor of saying your car has a 455 Pontiac in it (or Olds, or Buick, whatever it may be.). 455 buick is about the same weight as an SBC.
Cons - More expensive parts than an SBC, more $$ than a BBC as well. Not quite as much selection as far as aftermarket parts, especially compared to an SBC. More of a pain to shoehorn in to the car. Weird headers, remote oil filter, torque arm can't mount on tranny easily anymore, etc. (Just a few thoughts off the top of my head, probably ways around all of them, but those are just thoughts).
Read in the Engine swap forum, I think there's a sticky on a 455 Pontiac swap.
Old Feb 3, 2007 | 05:16 PM
yeah i read it but it didnt say what the diff. in a buick. olds. and pon. was. just wondering if one was better then the other
Old Feb 3, 2007 | 05:51 PM
They're all about the same as far as power. No particular huge difference.
Easier and cheaper BY FAR, to use a Chevrolet 454 in one of these cars. Get more power, cost less, easier to find parts for. Easier to make it BIGGER too.
Actually, a couple of parts DO interchange... you can use the same distributor module, rotor and cap in all of them, and the spark plugs will interchange between some. Maybe a few bolts too, like I think the intake bolts will swap. Oh, and the starter. Mustn't forget that.
Other than that, can't think of ANYTHING. I suspect that has something to do with why they don't exist any more. Why would any company in its right mind, that was attempting to make a profit by mass-producing something, make 5 versions of something that produce exactly the same result but are COMPLETELY different. Even F*rd figured that out by the mid 50s. IIRC the Lincoln motor was the last "other" one to get dropped, in about 55 or so. Not that the Chevrolet motors that they kept are any "better" or "worse", especially; at least not in ways that can't easily be fixed (like all of them's non-adjustable valve train, or those stupid "bridge" things they used for the rocker arms in Olds); they just needed to STANDARDIZE on something.
Old Feb 3, 2007 | 11:26 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Old 455? or Olds 455? 73 or prior pont. 455 in rebuildable cond. is worth bucks on E-bay. I got 300 for a bare block unbored 10 yrs ago. Block, heads, crank, pistons, intake, Ect. sold seperatly could finance a good small block. A big block in a 3rd gen. will bo a good job of twisting it into a piece of licorice stick without a lot of $$$'s into the body and suspension to control the torque. Ask anyone that has one.
BG87z
Mar 18, 2002 07:05 PM
427camaro
Nov 22, 2001 08:47 PM
jharms
Nov 6, 2001 12:57 AM
82camarov6
Oct 21, 2001 03:58 PM
