Rear ?cam? seal depth
Old Feb 4, 2007 | 09:20 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
At what depth am I supposed to install this seal? Flush?
Old Feb 4, 2007 | 09:21 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I guess this would help.
Old Feb 4, 2007 | 10:13 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Drive the plug in until the edge is just below the chamfer on the outer face of the block. If it goes in to far the cam will not be able to go in all the way.
Old Feb 4, 2007 | 11:52 AM
Right; just under flush.
Use the purple Permatex sealer, Brush Tack or whatever they call it. Sand around the edge of the plug with some 100 grit or so sandpaper to rough it up and make it stay in better. Coat that outside edge of the plug with the sealer, drive it in flush with a piec of 2x4 or something laid flat against it and one might whap with your BFH; then tap it in gently about 1/32" - 1/16" or so with a large socket or something, and wipe some sealer around the edge of it.
Freeze plugs in the water jacket should be done the same way. Since those are brass though (hopefully...), they're even easier to distort if you install them carelessly.
Old Feb 5, 2007 | 07:51 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I have some GM assembly adhesive that's specifically for oil. I should be able to use this, correct? Maybe my Teflon sealer?
Old Feb 5, 2007 | 08:24 AM
Don't use Teflon on freeze plugs. It's a lube. You want something that will keep them from accidentally popping out, not something that will make it easier for them to slide back out.
I don't know about whatever GM stuff it is that you've got. Not all adhesives are equal. Apart from "quality", there is the matter of suitability for a specific purpose (as above).
I know for sure that what I recommended, works.
Use something that hardens.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Exxon Limited
Aug 9, 2015 08:13 PM
anesthes
Aug 8, 2015 09:37 PM
