oil pan suggestions?
Old Feb 6, 2007 | 11:19 PM
stevemicaelo's Avatar
i am looking for an oil pan for my 383 in my 87 iroc.
i want a larger capacity but dont want it to be lower to the ground because i am lowering the car.i guess i want kick outs to the side and a oil scraper/windage tray.
does anybody have anything like this on their car or suggest anything.
\thanks
Old Feb 6, 2007 | 11:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A Moroso P/N 20205 might work, or a Milodon P/N 30909 or 30902. You'd have to add the windage tray or crank scraper.
Do you really need all that?
Old Feb 6, 2007 | 11:50 PM
ghotachevy's Avatar
go with the milodon and a good thick one piece gasket
Old Feb 7, 2007 | 09:57 AM
ostrich's Avatar
Car: 85 Iroc-Z
Engine: 383, Vortech SQ
Axle/Gears: Stock 7.5 w/ shafts, 3:73
I have the Milidon one on my 383 w/ Felpro 1 piece gasket. Works good, a little more capacity over stock. The car is lowered about 1" no problems.
Old Feb 7, 2007 | 03:21 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I was alwyas worried about the y pipe getting in the way of these things. You guys have headers ? I have th SLP's and was worried about hitting.
Old Feb 8, 2007 | 11:45 AM
ostrich's Avatar
Car: 85 Iroc-Z
I have SLP headers as well. The crossover pipe is tight against the pan, but it clears. I wrapped mine in heat (header) tape.
Old Feb 9, 2007 | 10:54 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Whats the differances between them two part numbers ? I would like one for the new turbo build up .
Old Feb 9, 2007 | 11:17 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
One is a stock type pan and one has more clearance for stroker cranks.
Old Feb 9, 2007 | 11:55 AM
SMM's Avatar
SMM
Be careful
I recently purchased some 1 7/8 long tube Headmen headers and they will not work with a kick out pan.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jk_Under
Sep 8, 2015 08:13 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
