Quick, Possibly Stupid Question
Old Feb 7, 2007 | 12:21 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Would upgrading from 1.5 to 1.6 rockers increase my rpm range (because of added lift) as well as increase horsepower, or just add some power, period?
Old Feb 7, 2007 | 03:18 AM
ede's Avatar
ede
in part it would depend where your RPM limiting factor is ,if it's valve lift then yes it'd increase it. if your limiting factor was intake volumn then no. depending on what you've done to the engine any increase would be slight and most likely unnoticable.
Old Feb 7, 2007 | 10:59 AM
See, my issue is that I am working with a cam that has a 1600-5400 rpm operating range. I picked this cam for my tpi setup, but I ended up swapping to carb, as the tpi was giving me problems, and now I have the potential to go to 6500rpm. I was hoping that the increase in lift might nudge my rpm up to 6000, if I was lucky.
Old Feb 7, 2007 | 11:04 AM
Superman04's Avatar
Car: Camaro
Engine: V8
Transmission: Automatic
Axle/Gears: Stock
what problems was the tpi giving you?
Old Feb 7, 2007 | 11:15 AM
Just the cam I picked up wasnt compatible, so I took the easy route out and switched to carb. I wasn't too concerned about mileage, and I really just wanted the car running. I tried the tuning thing but it just wasnt working out.
Old Feb 7, 2007 | 02:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Retarding the cam would be more effective at raising the RPM range than 1.6 rockers would.
600 RPMs is a lot to expect, though.
Old Feb 7, 2007 | 05:16 PM
I know it's alot, guess it's just wishful thinking.
Infested
May 22, 2018 11:56 PM
Cleotiz
Jan 6, 2018 08:56 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
gta power
Aug 13, 2015 06:15 AM
