Will this combo work???
Car: 86 Z28, 2000 Firebird, 2004 SSS
Engine: LG4 carb, 3.8, 6.0 HO
Transmission: Auto, Auto, Auto
Axle/Gears: 3.42, 3.42, 4.10
Here's the scenario,
I have a 88 305 roller block, .030 w/FT's. I have a set of 062 Vortec heads. I want to use the LT4 Hot cam kit. Dual plane intake w/650, HEI, Long tubes. This will be backed by a rebuilt 700R4 w/stock stall, and 3.42 gears. I would like to know if this combo will work especially the long block stuff (cam,heads,etc.).
Thanks in advance for your input and help.
Thanks, Steve
Thanks, Steve
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
thats a big cam for a 305 but it will sound really good and should really make good power, you will lose low end torque for high rpm power but it should work good with a 2500 stall and gear setup good luck and post some clips when finished
Car: '88 IROC-Z medium orange metallic
Stock converter is gonna hold you back, especially with that cam. It's not huge, but on the big side for a 305.
Thanks fellas,
What amount of stall would I need? (This is used as a weekend cruiser for my wife and I, and not a racer). If I kept the same stall & went with 3.73's or 4.10's would that help. Would I still get a little lope at Idle if I went with a 355 block with the same cam?? Thanks again guys for the help.
Steve
Steve
Transmission: 4L80E/4L80E
Vortec heads with stock springs/retainers/guides probably won't be able to handle the lift of the Hot Cam (assuming the "kit" included 1.6:1 rockers).
Stall depends upon use. Street driving, 2500 would probably be sufficient. Drag racing, you'd probably want 3000 minimum.
IMissMy86TA
Aug 31, 2015 08:40 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
