measuring pushrod length
Old Feb 16, 2007 | 07:58 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
nothing comes up in search for some reason, maybe if you dont want to get into it you could direct me to a post or article, for some reason im just not grasping it i dont think , heres what i think is right
bolt new heads on motor with new cam ,everything at tdc on compression stroke, put one of the rockers on with adjustable pushrod checker installed......................heres where im a bit foggy, does it matter what cylinder? do i have to do both valves? from what ive read, you coat top of valve with marker, with a couple of rotations of motor, it should wear away marker from just off center away from pushrod to just off center towards pushrod , am i close? i dont understand the base circle terminology..............
Old Feb 16, 2007 | 08:01 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Check out this link. http://www.circletrack.com/techartic...rain_geometry/
There a few theories and methods floating around. I personaly followed the above advice when I measured for my pushrods.
Old Feb 16, 2007 | 09:03 PM
wasp's Avatar
ive read that the marker method wont work with roller cam and roller rockers?
Old Feb 16, 2007 | 09:18 PM
wasp's Avatar
found another good article, see picture 2? says " with the lifter on the base circle of the cam" , what does this mean?http://www.circletrack.com/techartic...ushrod_length/
Old Feb 17, 2007 | 06:48 AM
wasp's Avatar
bueller?
Old Feb 17, 2007 | 09:26 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Base circle is at the bottom of the lobe. Completely closed valve.
Old Feb 17, 2007 | 10:00 AM
wasp's Avatar
same as tdc then right on compression right?
Old Feb 17, 2007 | 10:08 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I don't believe compression or both valves being closed at that point matters. Just when the cam is at the very bottom of the lobe for the valve you're measuring.
Old Feb 17, 2007 | 11:42 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Think EOIC. Exhaust opening, the intake is on base circle. Intake closing, the exhaust is just on the base circle.
And I thought you wanted to use a solid lifter for this test. Or modify a hydraulic lifter to be solid...?
Old Feb 17, 2007 | 01:29 PM
wasp's Avatar
well , ive read that too, how did most do it with roller lifters roller cam and roller rockers?
Old Feb 17, 2007 | 09:59 PM
wasp's Avatar
bueller?
Old Feb 18, 2007 | 03:09 AM
Sonix's Avatar
Car: 1982 Trans-Am
I'm pretty sure it works with roller rockers just fine, since they're SO common, and people do this pushrod length checking so...
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
AUZ28
Oct 3, 2015 06:28 PM
mfp189
Sep 27, 2015 09:25 AM
