Pushrods for a 305?
Old Feb 23, 2007 | 02:22 PM
Bane's Avatar
Pushrods for a 305?
I've got an 86 lg4 305. We're gonna be putting on a performer rpm qjet intake, a comp cams xe262h cam, and re-working the heads. What are the best pushrods for this set up?
Old Feb 23, 2007 | 03:10 PM
The standard ones that Comp recommends; I forget the part #. You can look them up in their catalog on the Net. They'll be 7.890" or 7.900" long, depending on whether you go with the normal ones or the "premium" choice.
Old Feb 24, 2007 | 12:39 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I recommend Manley pushrods, since I work for them.
http://www.manleyperformance.com/
Old Feb 24, 2007 | 09:32 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
stock length hardened ones such as summit racing ones would be fine and are inexpensive
imho
good luck
Old Feb 25, 2007 | 12:49 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I re-used my old ones...
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
TBRays98
Sep 6, 2015 05:05 PM
Formula_88AE
Sep 3, 2015 01:47 PM
willyjoejr
Sep 3, 2015 09:26 AM
