Anyone haul a Trans Am with U-haul trailer?
Old Feb 25, 2007 | 02:56 PM
Slick71ss's Avatar
Car: 87 Iroc
Axle/Gears: 3:27
I'm buying an 86 T/A and picking it up Weds. I have a u-haul car trailer or transport reserved to tow it home. I'm wondering if I'll run into any clearance issues while loading/unloading? Little worried about the front spoiler hitting.
Sorry if this is the wrong forum, but there isn't a general forum.
Old Feb 25, 2007 | 03:02 PM
THIRDGEN87's Avatar
Car: 87 FIREBIRD / 89 TRANS AM GTA
Engine: Ls1 / 350 L98 TPI
Transmission: 4l60e / 700R4
Axle/Gears: 3.73 / 3.27
hey thats funny. i just used the auto transport from uhaul to pull my formula home yesterday. i had no problems at all. rode nice on the trailer as well. there seemed to be enough clearance for your ta. you should have any problems. just dont use the tow dolly.....
Old Feb 25, 2007 | 04:10 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
When I moved out to CA many years ago, I had both, a U-Haul truck and their trailer. For me, traveling across the country, when I'd stop for the night, it was nice to not have to drive that truck around the towns. I'd just back the Formula off the trailer and go. I got a lot of experience on-and-off the trailer that trip, and everything worked great!
But if you're talking about the tow dolly, I don't have any experience with that. But I've heard you should remove the driveshaft before you pull the car.
Old Feb 25, 2007 | 04:34 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Pulled my 1992 home on the Uhaul trailer - not much clearance issues - the cable from the come-along wanted to rub the nose a tad, but there was snow on the ground, and it was too cold to argue at the time. With the dolley you have to remove the shaft IF it's an automatic, or you'll kill the tranny - 5sp just put in neutral.
Old Feb 25, 2007 | 04:36 PM
jlev22's Avatar
Yeah, just make sure you center it as much as possible. Otherwise it'll definitely catch on one side, I've seen it happen. But a trans will clear it up there.
Old Feb 25, 2007 | 05:18 PM
Slick71ss's Avatar
Car: 87 Iroc
Axle/Gears: 3:27
Thanks for the info! I had the owner measure the front spoiler ground clearance, and he said it was 8". I am getting the full trailer, not the dolly.
Old Feb 25, 2007 | 07:37 PM
Damon's Avatar
My brother and I have done this a million times on his various Trans Ams. It's tight, and it might rub a little bit just before the front wheels hit the ramps, but it'll get on there without doing any damage.
If you want a tip- bring a couple 3' lengths of 2x10 and lay them down in front of the ramps. That gets the front wheels up off the ground by 2" just before the nose cone starts to get close to the ramps. It can make enough difference that you shouldn't get any contact at all.
Old Feb 25, 2007 | 07:42 PM
Slick71ss's Avatar
Car: 87 Iroc
Axle/Gears: 3:27
Thanks. U-haul says the same thing about using the wood for cars with low spoilers. I'll bring some boards to be on the safe side.
Old Feb 25, 2007 | 10:45 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
I trailered my 87 T/A from NJ to MA a couple of years ago on a U-Haul trailer. DEFINITELY bring a couple of 2x10's with you. Air dam scraped with them. Bumper would have hit without them.
Old Feb 26, 2007 | 12:04 AM
kenf729's Avatar
Car: 1989 Camaro RS, 355, holley 650dp
Engine: flow master headers, 3" exhaust
Axle/Gears: stock
I actually used the tow dolley when I bought my 89 rs, but then It didn't have the engine or tranny...had plenty of room. was thinking that even if the engine and tranny was in there would have been enough gound clearance...
Old Feb 26, 2007 | 10:18 AM
drex's Avatar
Car: 87 formula and 85 olds delta 88 2 d
Engine: 60's 350 holley carb and intake
Transmission: muncie 4 speed with centerforce
Axle/Gears: 3.42 99 camaro rear w/ discs
also watch what truck you bring...sometimes uhaul wont even let you hook up until they check their computer to see if your truck can pull the load...and i tried to get a tow dolly for my 85 delta 88 (big like a caddy) and they said it was too large for a dolly... so bring a beefy truck... and when you shoot up the ramp keep it straight it will be tight... then hop out the window dukes of hazard style....yeehaw
Old Feb 26, 2007 | 04:05 PM
Slick71ss's Avatar
Car: 87 Iroc
Axle/Gears: 3:27
Yeah, you can check to see if your truck will be allowed to pull the load on their website. My truck isn't approved to pull an 86 Trans Am, so I'm gonna tow a 86 "Fiero" instead.
Old Feb 28, 2007 | 09:41 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I used their dual axle aluminum trailer to tow my IROC . It had inertia brakes and was a sweet setup . Didn;t need anything for it ....just drive it up and tied it down .
Old Feb 28, 2007 | 12:23 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
That shouldn't be necessary - I used a Ryder trailer to haul my GTA on my last interstate move, I was sure that I'd have to crawl out the rear hatch, but the door just cleared the fender over the wheels...
FWIW, I've had entirely too much experience with moving, and that experience has convinced my wife & I that U-Haul trucks are junk, pure & simple. They just seem to keep them too long, & let 'em run into the ground. My wife moved back a few weeks before I did, used a U-Haul truck & had a small engine fire... Thankfully her brother was there & was able to put it out, but it could've been ugly...
Old Feb 28, 2007 | 06:36 PM
Slick71ss's Avatar
Car: 87 Iroc
Axle/Gears: 3:27
All went great! I was prepared though. I brought a floor jack and jacked up the front of the trailer while loading. I also laid some boards down in front of the ramps and under the front wheels so the nose cleared the front. I have to admit, the newer uhaul trailers are sweet. They're light, have surge brakes, and built in straps.
Here's a pic of my new T/A on the trailer...
dustint209
Sep 9, 2015 08:09 AM
Thornburg
Aug 26, 2015 07:22 PM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
3rdgenparts
Aug 6, 2015 09:03 AM
