O2 Sensor
Old Feb 26, 2007 | 05:43 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
O2 Sensor
Where can i find the hole to put in the oxygen sensor? I think its in the exhast manifold but where?
Old Feb 26, 2007 | 06:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's in the driver side manifold.
Old Feb 27, 2007 | 02:10 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
thanks, im gonna go look.
Old Feb 27, 2007 | 02:19 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
ok i found it, and the wire that was once connected to it. How did the metal piece and the wire/hose connnect together, because they won't anymore.
Old Feb 27, 2007 | 03:42 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'm not sure what you mean. Can you post a picture of what you're talking about?
Old Feb 27, 2007 | 07:32 PM
Br0kenxFaith's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
I had the same problem. Your O2 sensor is probebly broken if its what im thinking of...( it is hanging, the piece that goes into the manifold wont connect, etc) you have to replace it and without taking any pieces off above it will make it a little difficult to reach, i got the piece in the manifold out with a regular socket from underneath the car and the other piece clips off from infront of the block and to get it in i did it from under the hood with a few extensions and a special socket that allows you to screw in things with wires connected to them if you pull it off this way becareful screwing it in because you dont want to break it again , they are somewhat fragile. Hope i was of help
Old Mar 2, 2007 | 07:05 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
yeah. Thats the same problem. I already bought a new one and hooked it up. I can only get it in finger tight tho. I can't find a way to get a wrench on there. And do u know why my car would be idling at like 2500 - 3000 rpms. It goes up and down and doesn't seem to want to go back down.
Old Mar 2, 2007 | 08:05 PM
fbodyorbust's Avatar
THAT IS CALLED "HUNTING" YOUR CAR DOSE NOT KNOW WHERE TO IDLE......THE ONLY REASON THAT I KNOW THAT IS BECAUSE IM HAVING CARBURERATER NIGHTMARES RIGHT NOW....IVE ALMOST GOT MY PROBLEMS BANGED OUT..BUT YOU MIGHT WANT TO START CHECKING THE VACUUM LINES.....BUT FIRST MAKE SURE YOU HAVE YOUR TPS(THROTTLE POSITION SENSOR) HOOKED UP....IT SHOULD BE UP ON THE FRONT LEFT SIDE OF YOUR INTAKE.BUT THATS WHERE ID START WITH THAT..........A 2500-3000 IDLE IS 1500 RPMS HIGH..AND THATS ON THE LOW SIDE..
Old Mar 2, 2007 | 08:39 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
thanks. ill check it out.
Old Mar 3, 2007 | 01:01 AM
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
I would also try using some fuel injection cleaner as well, have you replaced anything else on it recently because the o2 sensor breaking like that isnt that much of a "good" sign. If not i would recommend the usual full tune up, Cap/rotor, fuel filter, plugs/wires, etc... and these cars have a tendency to idle high when cold or like the previous reply a tps problem. Your car could also be "hunting" for fuel because its dirty or clogged which is why i recomend the fuel injection cleaner, if it was that it would idle higher to obtain the fuel needed to stay running, i would look into that because that is a rather high idle.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
