something i've been wondering about my engine for a long time...
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
when i first start my car in the morning (bone stock LG4, carb.) i have to hit the gas pedal before i even turn the ignition. not really a problem, but then it revs extremely high, i want to say around 2500ish, until it warms up for a little bit, then i hit the gas again and it settles into idle about 800 or so. what's the deal with that.
Car: 86Camaro RS
Engine: 2.8L V6
check out the choke, eletric/manual just check everything make sure it working properly
i also had similar pronlem with mine at first then it started to race, check vacum. I used wd40 spraying a light dusting over the vacum lines, when the motor changed sound i found the leak
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
normal, when the choke sets itself closed when you tap the gas the high idle cam also drops into place which keeps the idle up to prevent stalling when its cold.
Once it warms up and the choke opens up it also releases the high idle cam and allows it to idle down after you push the gas enough to take pressure off the cam allowing it to drop back.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
although 2500 is a bit high, even for a cold fast idle speed, imho
but if it only does it when its totally cold then its normal yeah
even so, if it were mine i would unscrew the fast idle screw a bit and lower it closer to 2000 rpm or so
factory LG4 fast cold idle is 2200 rpm though but i dont like to run my cold engines that fast
and having to depress the pedal at least once when its cold is how you set/close the choke so that it will fire right up and run on the highest step of the fast idle cam on the choke linkage part of the carb
NinjaNife
Aug 23, 2015 11:49 AM
