Serious e-brake issues!
Old Feb 26, 2007 | 07:51 PM
nks06's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L LB8
Hey guys-
I'm worried about my ebrake. Let's say I'm on an incline. i put my foot on the brake, shift into neutral, and apply the ebrake. I pull the lever up all the way, and my car will still roll away. I don't know what's going on. Any ideas?
Old Feb 26, 2007 | 07:59 PM
EvilCartman's Avatar
Car: '82 Z28
Needs to be adjusted or checked for broken cables. The adjustment is up in the trans tunnel under the car where the single cable splits into two, or at least on mine it is. Another thing is to see if the cable(s) are still in their guides in the trans tunnel.
Old Feb 26, 2007 | 08:39 PM
nks06's Avatar
Engine: 2.8L LB8
thanks
I took my car in for trans work and it hasnt worked since. I need to take it back to them for a warranty thing, i'll have them look at it.
Old Feb 26, 2007 | 10:44 PM
Vader's Avatar
And pre-1988 rear calipers require periodic lubrication of the caliper actuator screws and levers with clean brake fluid. I'm sure I do mine once a year when I lubricate everything else on and under the body.
Old Feb 27, 2007 | 09:13 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Also, if you have drum brakes, the mechanism may not be self-adjusting properly. You can remove the drums to inspect and adjust the adjuster wheel by hand. Extend the brake shoes until they just drag on the drums and check the cable adjustment. That should get the e-brake working again.
Old Mar 6, 2007 | 05:57 PM
nks06's Avatar
Engine: 2.8L LB8
well...
I went to take a look at my rear drums..and what did I find?
a dry-rotted wheel cylinder!
So I replaced them (pass and driver) and no dice on the ebrake
I looked in my chilton, and it looked like the adjusting screw thing was by the handle under the console, but its not exactly clear. is that correct?
Old Mar 7, 2007 | 12:23 AM
Car: '82 Z28
Not sure about the handle but under the car on mine is where one is.
Old Mar 7, 2007 | 05:44 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
In the tunnel above the drive shaft.
JamesC
Old Mar 7, 2007 | 07:50 AM
nks06's Avatar
Engine: 2.8L LB8
thanks guys
Old Mar 7, 2007 | 10:20 AM
Car: 88 Camaro SC
Engine: SFI'd 350
When the cable is properly ajusted, it should be slightly taught. If it alreay is, and theres no slack in the cable, then the problem likely resides elsewhere.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
