car no stardy
Old Feb 28, 2007 | 10:03 PM
raiders8498's Avatar
Car: 88 Trans Am
car no stardy
i have 88 gta and it wont start, its a ignition problem because i toke a spark plug out and it was wet with fuel, so i changed the ignition module and nothing now im thinking its the coil what do you think
Old Feb 28, 2007 | 10:44 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
well i believe you have 2 coils the pickup coil and the ignition coil...
when was the last time you did a tune up?
i mean plugs cap rotor that sorta stuff...
now by it wont start do you mean at all or for a couple of seconds or wont turn over?
what engine what mods what did you break in the past few days
Old Feb 28, 2007 | 11:41 PM
Car: 88 Trans Am
i put a new cat and my rotor and cap i changed about a year &half. it turns over almost sounds like its going to start but does not start
Old Mar 1, 2007 | 12:15 AM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
change the plugs and wires, just pick up cheepies, should be able to get them for under 30$, then start testing and changing more expensive stuff. So many times i have found on old cars it is deteratied contacts on the plug wires.
Old Mar 1, 2007 | 12:37 AM
Car: 88 Trans Am
i have msd wires but ill probly get cap rotor and pugs
Old Mar 1, 2007 | 03:56 PM
Car: 91 RS
Engine: 350 vortec
just cause they say msd on them doesnt mean they are any good
Old Mar 1, 2007 | 04:48 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
do you have a ohm meter? measure the resistance in the wires, fried my first set on my headers.
Old Mar 2, 2007 | 09:43 PM
Car: 88 Trans Am
that is true my wires sometimes hit the air tubes to the headers.
Old Mar 2, 2007 | 09:51 PM
Car: 88 Trans Am
i changed the ignition module and nothing, then i checked if spark was comming out of the coil and no spark so i got a coil today and they gave me the wrong one so ill have to go back tomorrow
Old Mar 4, 2007 | 10:30 AM
Car: 88 Trans Am
i was testing the power going into the coil and the constant power has 12v and the signal wires dont read nothing so what could it be my ditributer, magneto, or the ECM. need help!!!!!!!!!!!!!!
Old Mar 4, 2007 | 07:35 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
sorry i am out of ideas, bout now i just start replaceing ****.
Old Mar 4, 2007 | 08:50 PM
Car: 88 Trans Am
that is what i was going to do but dont want to buy part i dont need bucause i was just getting starting to build a new engine
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
