305 or 307 ???????
Old Mar 1, 2007 | 01:16 PM
diablo666mew's Avatar
Car: 89 camaro RS convertible
Engine: 305 tbi
305 or 307 ???????
ok i nead to no how i could find out if i have a 305 or 307 in my 1985 digital berlinetta camaro how do i go about doing that ???????????
Old Mar 1, 2007 | 01:45 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
It's a 305.
Old Mar 1, 2007 | 01:47 PM
Engine: 305 tbi
not if the motoer has been changed how can i check useing the numbers on the block ?
Old Mar 1, 2007 | 01:49 PM
Sonix's Avatar
Car: 1982 Trans-Am
How much you wanna bet it's a 305? Maybe a 350, but not a 307.
Look for the casting # behind the drivers head. It's nearly impossible to see, so good luck. Dig and scrub and you should see a 5.0 or a 5.7 on it. Also the casting number itself, which you can look up at mortec.com to confirm.
Old Mar 1, 2007 | 01:52 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
ok ill bite since im really amused by this thread and am curious too lol
what makes you think its possibly a 307 if its not the original 305 ?
of all the engine sizes chevy made why do you pick 307 ?
its highly unlikely, but not impossible its most likely a 305 or 350, over anything else
why dont you give us numbers off the engine
if the balancer is really small and really skinny then its pretty possible its a 307 or 327
but if its really wide then its a 305 or 350
Old Mar 1, 2007 | 03:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
http://www.mortec.com/castnum.htm
Old Mar 1, 2007 | 03:44 PM
Engine: 305 tbi
the cast number is
3931633 it was rebilted a wile back by a friend of mine and i am prttey sure it is a 307 because that is the moter i want it an the guy i bot it from has not lied to me yet y i wanted a 307 just because u never see them much and i like to be weard but if some 1 can find out for sure it is a 307 tell me thax
Old Mar 1, 2007 | 03:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's probably a 307, but that's a head casting number. You need the casting number from the block.
Old Mar 1, 2007 | 05:04 PM
krly79's Avatar
Car: '93 S10 Short bed standard cab
Engine: 383 Stroker
Transmission: 92' stage 2 700r4 w/3600 stall
There is a reason why you don't see many 307's. They were produced using a very low nickel casting alloy that made them soft and reduced longevity.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
