What is this?
Old Mar 3, 2007 | 01:22 PM
codeysabatini's Avatar
Car: 91 RS
What is this?
Both pics are of a 400 SBC, In the first pic there is a bolt which idk why its there or what its there for? The second pic is a picture of the opposite side which appears to be a small freeze plug? If so why would there be a bolt in the first one?
Old Mar 3, 2007 | 01:37 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
well i believe that would be a coolant drain plug in the top pic
Old Mar 3, 2007 | 01:38 PM
Car: 91 RS
Doh, can't believe I didn't think of that lol, thanks
Old Mar 3, 2007 | 03:33 PM
Car: 91 RS
Engine: 350 vortec
and the same on the other side as both banks need to be drained seperatly
Old Mar 3, 2007 | 04:02 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'd throw in a petcock. You can find 'em in the parts stores where they have the brass fittings and whatnot, I think it's 1/8"NPT. That makes it easier to drain/flush later.
Old Mar 3, 2007 | 04:08 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i put allen head plugs in my block and i couldnt get them off.. i just spun the wrench.. petcock it..
Old Mar 3, 2007 | 04:09 PM
Car: 91 RS
Alright, thanks for the info guys. But in the second picture that is not a bolt there, to me it looks like a smaller freeze plug? Should I leave that "plug" there or turn that into a petcock also? Thanks again for the info
Old Mar 3, 2007 | 04:14 PM
Car: 91 RS
Engine: 350 vortec
i believe that is a threaded hole so it might be an allen screw that has been stripped out... but i would replace it with something wether it is a petcock or freezeplug or even a square head bolt in a rebuild why cheap out on a 95 cent piece\
BTW like your engine stand autozone special... did you get the engine hoist with it too? i folded my autozone hoist...an inline 8cyl desiel with ZF hurth transmission weight more the 1500 lbs
Old Mar 3, 2007 | 04:19 PM
Car: 91 RS
Yeah, I got the engine hoist with it also lol seems to work fine so far but I just used it to pull my 305 and 700R4.
