Piston Size?
Old Mar 10, 2007 | 09:08 PM
8996chevy's Avatar
Car: 89 IROC
Engine: 355
Transmission: 5 sp., Alum Driveshaft
Axle/Gears: 3.73 Posi
Piston Size?
Just bought a 350 tpi engine to rebuild, while cleaning up the pistons I noticed on the top of all the pistons is stamped ".030". Does this mean the engine has been bored .030 over? also does anyone know what the crank main journals and rod journals diameter is? thanks
Old Mar 10, 2007 | 09:18 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Yes that is what that .030 means, and 2.45 and 2.10 is the journal sizes
Old Mar 11, 2007 | 06:50 AM
ede's Avatar
ede
mains 2.448-2.449
pins 2.098-2.099
there's a slight variation depending on which journal you're checking. all the info ought to be in your manual, or you need a new manual.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
PurelyPMD
May 5, 2016 04:57 PM
Nervous2
Oct 8, 2015 10:53 PM
Linson
Sep 21, 2015 01:08 PM
m00n420
Sep 11, 2015 02:39 PM
