CASTING #s FOR VORTECH HEADS
Old Mar 13, 2007 | 01:48 PM
lugnut's Avatar
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
Hey, I was wondering if anybody could give me a clue as to what the casting #s for vortech heads are.I am about to buy a used set and want to make sure I get what I pay for The last 3 is 187,what chamber,runner valve size.Is it worth buying a used set,thanks
Old Mar 13, 2007 | 01:51 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Those heads are not Vortec heads. "187" heads are Swirl port heads. Good for stock or near stock applications.
Old Mar 13, 2007 | 01:52 PM
187 is THE ULTIMATE GARBAGE; 305 swirl-port TBI heads.
If somebody is telling you those are Vortecs, they're trying to rip you off.
The ONLY Vortec casting #s are 906 and 062. All other numbers, are some other kind of head. There are no "early Vortecs", no "almost Vortecs", no "just like Vortecs", and so forth. Voretc is GM ad-copy lingo for "we moved the intake ports to a different place; they're ¼" closer to the valve cover now".
Old Mar 13, 2007 | 04:05 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
they do have 2 or 3 305 vortecs i have a set casting 520. we have debated it and they flow quite well for a stock 305 head... they dont have the same chamber shape but the ports are the same the runners are raised they have 58cc chambers. do a search 305 vortec and you will find the article with flow numbers...
Old Mar 13, 2007 | 04:12 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
yea, 305 vortecs, making them, ...."almost vortecs", or "barely vortecs".... 187's are what i'd call "Nowhere close to vortecs".
Run far from that guy trying to pass those heads off as vortecs.
Old Mar 13, 2007 | 04:26 PM
lugnut's Avatar
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
Hey thanks a hell of alot for the info and the quick response,you guys rock!
Jynx88
Oct 4, 2015 08:19 PM
355tpipickup
Sep 28, 2015 05:50 PM
Jonas Earl
Sep 27, 2015 07:39 AM
anesthes
Sep 18, 2015 12:34 PM
355tpipickup
Sep 13, 2015 11:35 PM
