Car won't start after working on it.
Old Mar 14, 2007 | 08:04 PM
Genhero's Avatar
Hello, Im just getting into cars so I'm not very good at troubleshooting problems yet. I did a diverter valve delete, plugged the Y pipe and connected the two tubes that are back at the firewall together. I also installed new valve covers. I undid the spark plug wires boot from the distributor on the passanger side to work but when I was finished it started to drizzle. By then I was finished and plugged the boots back into the distributor and put the ground back on the battery. When I go to start the car now it just click once and then completely dies, no lights or ignition what-so-ever. I went to close my hood and when I did the alarm went off and I get all my lights back. I go to turn the ignition back on, and the same thing lights and all power goes back out until i slam the hood. Please help I have class again on monday.
Old Mar 14, 2007 | 08:15 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
you have a bad ground connection at the battery ensure all connections are very snug
Old Mar 14, 2007 | 08:16 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
It's something electrical obviously, VATS comes to mind. Try checking to see if you arc'd something maybe the ignition coil and re-check all ground connections, clean them if they need cleaning it will make a difference.
Old Mar 14, 2007 | 08:27 PM
Genhero's Avatar
thank you for such the quick replys I will recheck everything in the morning, the one bolt I know i did not tighten very well because the new valve covers got in the way was the tube going from the throttle body to the master brake cylinder. I didnt tighten the bolt that helps it run down the intake manifold. Thanks again for the help Ill check all bolts and ground tomorrow
Old Mar 15, 2007 | 06:29 PM
DMitchell05's Avatar
Keep us informed....
Old Mar 16, 2007 | 12:00 PM
Genhero's Avatar
will do, i randomly got sick and it started snowing so i wont be able to work on it until it stops.
Old Mar 16, 2007 | 01:44 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Originally Posted by Genhero
I did a diverter valve delete, plugged the Y pipe...
Old Mar 16, 2007 | 02:11 PM
Genhero's Avatar
not y pipe as in exhaust y pipe. there is a y tube(i guess would be a more clear way of saying it ) that runs from the radiator to the firewall and a tube that comes off of that tube and gos up to the top of the valve covers were the other tubes are.
Edit: on second thought its more of a T
Old Mar 21, 2007 | 05:53 PM
Genhero's Avatar
Re: Car won't start after working on it.
I got to work on the car today. The negative on the battery was alittle lose so I cleaned it and tightened it and the car started right up. Thanks for the help only took 5 mins to fix when I knew what to look for. Next time Ill remember to pull it in the garage incase it rains so I wont be rushed. Thanks again
-Russ
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
hokis
Aug 9, 2015 03:57 PM
MENINBLK
Aug 5, 2015 11:58 PM
