Sealant for freeze plugs
Old Mar 18, 2007 | 09:02 PM
codeysabatini's Avatar
Car: 91 RS
What kind of sealant do you guys use when you install your freeze plugs, i need to install brass ones if that makes any difference.
Codey Sabatini
Old Mar 18, 2007 | 09:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If the block is in good shape and not pitted by corrosion they don't need sealant, but a little RTV doesn't hurt.
Old Mar 18, 2007 | 11:36 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i have always used something like Permatex #3 & had good results.
Old Mar 19, 2007 | 03:25 AM
ede's Avatar
ede
same here, freeze plugs isn't some place i'd want RTV.
Old Mar 19, 2007 | 10:14 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I use red loctite
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
Stryker412
Sep 20, 2015 06:59 PM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
