Cam Break in troubles
Old Mar 18, 2007 | 09:34 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
I recently installed a new flat tappet lunati cam, trickflow heads, and a edelbrock tpi manifold. I installed the cam at dot to dot. Pointed the rotor at the #6 post on the dizzy, and this afternoon i attempted to break it in. After about 3 minutes the headers were glowing bright red, had a small coolant leak and my brother said he heard some lifters ticking. It was running reaaaaal rough i had a hard time jus trying to keep it between 2,000 & 3,000 rpm it was all over the place, so i shut it down. I know i need to recheck the valve lash and do something with the timing? Im guessing I need to advance it? CounterClockWise to advance? Should the EST wire be disconnected?
Old Mar 19, 2007 | 12:43 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Counterclockwise to advance, EST connected.
Bubbajones_ya
Aug 31, 2015 12:02 PM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
bdads
Aug 24, 2015 06:01 PM
89fast5oh
Aug 24, 2015 08:14 AM
cstrobel65
Aug 15, 2015 10:19 AM
