EGR solenoid replacement
Old Mar 21, 2007 | 10:25 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
I have an 350 TPI. I have a broken wire coming from the egr solenoid to the egr valve. I need to replace the egr solenoid and am wondering if I need to take the plenum off or can i seek the wire under it. Does anyone know how to take off the egr solenoid.
Old Mar 28, 2007 | 11:33 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: EGR solenoid replacement
yes the actual EGR is under the plenum. The EGR solenoid i would buy from the dealer you need a specific one and after market never matched my car.
also the solenoid is being held down by one bolt. remove the hose lines to it and you should see it.
i did this on my 1986 305
hopefully they are similar in part locations
goodluck
jklein337
Sep 19, 2018 06:23 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
drathaar907
Aug 6, 2015 04:20 PM
