Bad lifter?
Old Mar 26, 2007 | 12:57 PM
camaronut79's Avatar
Car: 1983 z28
Engine: 383 .060=388
Transmission: th350
Bad lifter?
Well while im up here in pa attending school it seems that my car(back home in florida) has started making a noise which is in my dad's opinion and mine (from the vid I seen and from what he has told me) I belive it to be a bad lifter. he told me its coming from the passenger side around the #6cyl when he removed the valve cover he said the #6 intake pushrod had some play in it, he adjusted the valve, it was fine for a few secounds then the tapping started agian. oil pressure is great (55psi cold idle 35psi when warm). tapping does not go away when warmed up.
heres the video http://video.google.com/videoplay?do...66745259&hl=en
Last edited by camaronut79; Mar 26, 2007 at 12:58 PM. Reason: Automerged Doublepost
Old Mar 26, 2007 | 01:03 PM
cool84's Avatar
Car: 84 trans am
Transmission: built 700r4
Re: Bad lifter?
vid link doesnt work. just comes to video search
Old Mar 26, 2007 | 01:08 PM
Car: 1983 z28
Transmission: th350
Re: Bad lifter?
sorry try this also this is on the 383 I built http://video.google.com/videoplay?do...66745259&hl=en
Old Mar 26, 2007 | 01:09 PM
Re: Bad lifter?
Lifters don't generally "go bad" like that.
This a fairly new motor?
Sounds like a rolled cam lobe unfortunately.
Does that rocker move about the same amount as the others, or ALOT less?
Old Mar 26, 2007 | 01:14 PM
Car: 1983 z28
Transmission: th350
Re: Bad lifter?
roughly 20 hours on the motor, it moves the same amount as the others.
Old Mar 26, 2007 | 02:38 PM
ljnowell's Avatar
Re: Bad lifter?
what kind of hardware. I have had regular rocker arm nuts back off lots of times. Had one do it three times before we "double nutted" it to make it quit. Personally i would check this out before thinking about replacing a lifter. A good dial indicator would be nice too, measure the actual amount of lift, and compare it to another valve and see if its the same. Make sure the lobe isnt going flat. Doesnt take long and will give a definitive answer.
Old Mar 26, 2007 | 04:28 PM
Car: 1983 z28
Transmission: th350
Re: Bad lifter?
full aluminum roller rockers with poly locks.
I have a new solid cam and lifter set from crane I planed on putting in there, now maybe sooner then later. but it wont go in for another 3months
(when I graduate)
tyeo098
Nov 30, 2015 06:27 PM
RyanJB
Sep 14, 2015 03:39 PM
Stryker412
Sep 7, 2015 09:11 AM
dimented24x7
Sep 6, 2015 03:51 PM
z28guy134
Sep 1, 2015 11:50 PM
