Surging Idle... Could it be The voltage regulator?
Old Mar 27, 2007 | 06:53 PM
BigBoi4Lyph's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
I saw on a form that surging idle with a volt meter that surges with the rpm gauge exactly could be a voltage regulator...
Im trying to get down to the bottom of my surging problem and i havent gotten anywhere and then i came accross that which is the EXACT same problem im having...
So can a voltage regulator being bad cause a surging idle and how?
Old Mar 28, 2007 | 06:14 AM
babsirocz's Avatar
Re: Surging Idle... Could it be The voltage regulator?
When you say "surging" problem, is it when the car is sitting idle, or running at a stop, or after it is warmed up, when it is first started and cold?
Old Mar 28, 2007 | 06:47 AM
No.
You've got the cause and the symptom mixed up. As did whoever wrote that humorous thing about the voltage making the idle surge. That's pretty funny. consider it "entertainment", but not "technical".
The voltage is changing because the engine RPM is going up and down; not the other way around.
Clean your IAC. Leave the alternator alone.
Old Mar 28, 2007 | 07:38 AM
blackroc68's Avatar
He has a carb> no iac
Old Mar 28, 2007 | 08:41 AM
Maybe... hard to be sure...
The symptom he describes goes with fuel injection.
Look at his profile.
Maybe he has 2 cars.
Maybe he should tell us that himself.
Old Mar 28, 2007 | 10:54 AM
Car: 89 Iroc
Engine: 5.7 TPI
I have an 89 Iroc 5.7 TPI ICA is bran new, TPS is ajusted and had no dead spots, just did a tune up yesterday and the plugs were all covered in carbon, Ajusted min air accor5ding to the tech article, no codes, New MAF Good relays
The one thing i did notive is that when i unplug my o2 sensor it dosent change or throw a code...
And the surging is at idle in park or N and in Drive idling at a stop or even cruzing when rpms are 1500 or less
Sounds like detonation causing the surge so air fuel because i know it running on all 8 and my shop teacher verified.
And its on when its warm when its cold it runs like a champ then when it trys to idle down at about 160* it start surging.
Anything else. Thanks for the help!
Old Mar 28, 2007 | 11:17 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Check your fuel pressure. Could be a fuel pump issue or a fuel pressure regulator problem.
Old Mar 28, 2007 | 05:19 PM
Car: 89 Iroc
Engine: 5.7 TPI
i check fuel pressure when it was in open loop mode and it was 40 psi but the car dosent start surging untill closed loop so i need to check fuel pressure when it surges to see... O2 sensor check good and the pc is reading it .2 to .6 .2 to .6 ect ect and the car switches from rich to lean mode very fast...
BLMs are 109 to 128
What are BLMs any ways..
Old Mar 29, 2007 | 01:08 AM
mnorton's Avatar
Engine: 305 LB9 TPI
BLM=Block Learn Mode
Basically it's a rough indication of air/fuel ratio via the O2 Sensor. 128 is great, 109 is on the rich side. Switching from Lean to Rich very fast while in closed loop is normal.
Old Apr 14, 2007 | 01:13 PM
Car: 89 Iroc
Engine: 5.7 TPI
alright sounds good i also found i had a code 13 it come up while driving on the freeway then went away but it was saved in my ecm. o2 lean at cruse i beleave i cant find a code list but im sure thats what it is.
Old Dec 27, 2018 | 12:31 PM
Aussie03's Avatar
hey. I am having this same exact problem with my 1988 Dodge Ram TPI 318. I was wondering if you ever found a solution to you problem. Thank you
Old Dec 27, 2018 | 12:45 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Tpi on a 318 ??
are you using a gm ecm ?
have you followed the advice above by cleaning the iac.
the surging could be fuel related , injectors weak fuel pump.
if this is not a gm based question you should seek another forum. This is a old dead thread.
Old Dec 27, 2018 | 11:29 PM
popitas2's Avatar
Car: 1988 Iroc z
Transmission: f4
Help, my 1989 Firebird, 350 TPI rpm's rev up and down when i start the car, then levels off when car gets warm. What is the problem? I installed plugs, wires, rotor, cap, ignition coil and it runs better, but still rev's RPM's when I start it in the morning. Some guy told me my MAF may be bad. i know plug number 3 has gas when I removed it. it has new fuel pump. It also hesitates from a standing start. kinda of shakes also.
Old Dec 28, 2018 | 12:49 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Check your grounds. Battery, back of heads, block.
Old Dec 30, 2018 | 04:06 PM
Aussie03's Avatar
Tpi on a 318 ??
i know now this is a gm forum it’s just that this forum had very similar problems to the ones that I am having. And I’m sorry I meant to put tbi 318. I’ve just ran out of other ideas of what the problem can be and thought I would give this a try. I have checked the injectors and they look to be spraying good and even on both banks. I have also recently took out the fuel pump and everything seems good there too. Sorry for the confusion.
Mark_ZZ3
May 24, 2018 01:02 PM
gixxer92
May 18, 2017 11:20 AM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
Dragonsys
Sep 25, 2015 03:51 PM
