seafoam treatment
Old Mar 28, 2007 | 06:00 PM
1988CamaroSC's Avatar
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
seafoam treatment
just poured some b12 chemtool (basically seafoam) down the booster vaccum line in my 2.8. she didnt like that idea 1 bit, wouldnt even idle w/o throttle input with the line off. i did manage to get half the can in but wow i never saw the car surge so much on its own. i hope it works well, i think shes dirty on the inside causing some ticking, the motors only got 74k. anyone else use this?
Old Mar 28, 2007 | 06:33 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Re: seafoam treatment
seafoam is mostley water, chemtool is all chemicals. I use seafoam and swear by it, but i only use chentool in the oil before a change evrey once in a while.
Old Mar 28, 2007 | 08:44 PM
Pyrice4's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1L V6
Transmission: M5
I used some seafoam, car almost died while i was putting it in but runs alot better now.
Old Mar 28, 2007 | 11:40 PM
Vader's Avatar
Try a smaller vacuum line to administer whatever cleaner you choose. The brake booster line is a huge vacuum leak.
Old Mar 29, 2007 | 01:35 PM
Car: 92 Camaro RS
Engine: 5.0L
yeah chemtool was crap. i wasnt happy so i went out and got seafoam, what a difference, i almost smoked out my neighbor hood, car took half of the can before she called it quits with my girl on the pedal about 2500rpm. not much smoke on the drive, but it smoked like hell when i was applying it, i had to hold my breath for like 45 seconds and then when the car stalled my girl runs out into the house yelling that stink omg i cant breath haha because her window was down.
Old Mar 30, 2007 | 10:19 AM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
good to hear it worked for you, I use it on all my older, high mileage cars bout twice a year, half can or so each car. Always worked great.
Old Feb 25, 2008 | 10:44 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
i just tryed the seafoam, used 2/3 of the can put the rest in the tank. im skeptical i did see alot of smoke but so far no improvement in anything still runs the same as it always has. is there suposed to be an impovement right aways or does it take a certain amount of miles?
Old Feb 26, 2008 | 08:03 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
i swear by seafoam, i use it regularly in all of my cars. they always run bettedr after i use it, but it usually runs a little rough when you are pouring it in. after that they always run wayyy better.
Old Feb 26, 2008 | 10:22 AM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
since putting my crate motor in a yr ago i have only drivin the 91 rs 3000 miles......will seafoam benefit me any?
Old Feb 26, 2008 | 10:31 AM
dunnellon86's Avatar
Car: 89 firebird
Engine: 2.8 mpfi
Axle/Gears: stock
i just got some seafoam today if the break booster line is too big then what vac line do i use?
Old Feb 26, 2008 | 11:43 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Seafoam is light oil, alcohol, and naphtha. No water.
Old Feb 26, 2008 | 03:35 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
I stand corected.
Old Feb 26, 2008 | 04:03 PM
kanmudhog's Avatar
Car: 89 formula ws6
Engine: yes
Transmission: yes
Axle/Gears: both
What are you guys treating ? Are you trying to get the carbon off the valves ? Will it affect the o2 sensor or the cat ?
bryan623
Mar 22, 2021 06:43 PM
gta892000
Aug 11, 2019 11:16 AM
86White_T/A305
Mar 6, 2016 01:48 PM
HoosierinWA
Oct 7, 2015 10:15 AM
rjcme
Sep 5, 2015 01:23 PM
