Getting Accessory holes for heads?
Car: 91 RS
I just got a set of aluminum heads in the mail i bought off a guy and it turns out they do not have the accesory holes for the powersteering and alternator
, is it possible for me to drill these myself or have a machine shop do it? or should i start looking to get new heads?
Codey
Codey
Re: Getting Accessory holes for heads?
Depends on the heads. What are they?
Stock heads, you CANNOT drill & tap, because there's no metal there to drill and tap. No bolt hole boss cast in.
Aftermarket heads could be a different matter. But I kind of doubt it.
Personally, I'd return them and get the right thing. I would SURE AS HELL not risk ruining a possibly useful set of heads by trying to shadetree it.
Car: 91 RS
they are aftermarket heads, and i bought them off a guy not a company so it will probably be a pain trying to get my $$ back if i can even get it back.....
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
i know of a place you can get the power steering bracket, used it on my camel hump heads and no accessory holes.
http://www.yogisinc.com
with a long water pump you'll need item # 402L
its looks pretty sick with nothing on the heads also.
evilstuie
Jan 9, 2020 08:29 PM
355tpipickup
Aug 27, 2015 08:13 AM
thanks a ton for pointing that out to me!
