86 camaro timing
Old Apr 2, 2007 | 04:42 PM
dahn's Avatar
Car: 86 camaro
Transmission: 700 auto
Axle/Gears: 308
86 camaro timing
I have a 86 camaro with a 305 feedback style carb. My question is on the timing. My repair book say disconnect the black and tan wire first before setting the timing. Well my black and tan wire is already disconnected and taped up.And the connection where it is suppose to go is gone.All that looks like in the repair book is a black cap that the wire goes to.How should I go about setting the time?It runs fine I took the distributor out and put it back in and just want to check the timing because it seems a little doggy like the timing needs to be advanced. Thanks
Old Apr 2, 2007 | 07:09 PM
j dezzy's Avatar
Car: 87 TA
Re: 86 camaro timing
What is your current timing at? Or have you not checked it yet?
Old Apr 4, 2007 | 04:38 PM
dahn's Avatar
Car: 86 camaro
Axle/Gears: 308
Have not checked it yet.
Old Apr 4, 2007 | 04:57 PM
j dezzy's Avatar
Car: 87 TA
First you gotta get a timing light and see what you're at right now. should be 6* BTDC.
Old Apr 5, 2007 | 10:41 PM
raiders8498's Avatar
Car: 88 Trans Am
how do you check it with a advance timing light
Old Apr 5, 2007 | 10:55 PM
j dezzy's Avatar
Car: 87 TA
Hook up the light like you would any other timing light. Then turn the **** to the degree that you're looking to set to. loosen the distributor start up the engine and turn the distributor till the timing marker on the balancer is at 0* BTDC.
Old Apr 5, 2007 | 11:11 PM
Car: 88 Trans Am
so can my timing be that off it falls at around 30-43 what the problem
Old Apr 5, 2007 | 11:12 PM
j dezzy's Avatar
Car: 87 TA
what do you mean falls around 30-43?
Old Apr 5, 2007 | 11:24 PM
Car: 88 Trans Am
i have the **** at 30-43
Old Apr 5, 2007 | 11:26 PM
j dezzy's Avatar
Car: 87 TA
oooo....way too much. you should have it set at about 6.
Old Apr 5, 2007 | 11:31 PM
Car: 88 Trans Am
but i move the distributer back and foward and i can get it closer will it be that the distributer is placed wrong i took it out
Old Apr 5, 2007 | 11:34 PM
j dezzy's Avatar
Car: 87 TA
It doesn't matter which was you put the distributor in as long as the needle in the distributor rotor is pointing at the number 1 plug wire and the engine is at top dead center.
Old Apr 5, 2007 | 11:40 PM
Car: 88 Trans Am
it points straight so i move the distributer to the right for it to hit no 1
Old Apr 5, 2007 | 11:45 PM
j dezzy's Avatar
Car: 87 TA
you have to take the distributor cap off to check. make sure the rotor is pointing at the number 1 plug wire. It doesn't matter which way the distributor itself is pointing, just as long as the rotor is pointing at the number 1 plug wire. and from there you have to make sure that your engine is at top dead center. then the timing can be properly set...as long as your balancer and timing tab are indexed correctly.
Old Apr 5, 2007 | 11:49 PM
Car: 88 Trans Am
alright ill take everything appart and start from scratch this weekend
Old Apr 5, 2007 | 11:53 PM
j dezzy's Avatar
Car: 87 TA
the whole process, setting up the distributor, getting the engine to TDC, and setting the timing doesn't take long. maybe a half hour if you've done it before. But this is something that you definatly want to get right. getting your timing right will save you gas, get you that little extra HP, and is a lot easier on your engine. good luck, let me know if you need any more help.
Old Apr 5, 2007 | 11:56 PM
Car: 88 Trans Am
alright thnx
Old Apr 5, 2007 | 11:57 PM
j dezzy's Avatar
Car: 87 TA
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Linson
Aug 21, 2015 02:12 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
