engine balancing woes
Old Apr 5, 2007 | 10:26 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
so i buy this rotating assembly pre balanced on the latest hines machine. i take the kit to be installed to my local shop, they have it about a week and call me to say i need to re balance it. they said the eagle pistons difference from heaviest to lightest was 3 grams difference. and rods 1.5 grams. the company i bought the kit from said impossible. the shop said my engine would rattld apart at 7000rpm. what do you guys think i should do? oh ya, the shop wants 380 for the pro rebalance
Old Apr 5, 2007 | 10:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: engine balancing woes
If you paid for it to come balanced and it isn't, I'd try dealing with the company you bought it from.
Old Apr 5, 2007 | 11:29 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
yeah the company you bought it from or another machine shop see if they are liars trying to pork you... never know
Old Apr 6, 2007 | 01:08 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
is 3 grams a big deal for a 7000rpm engine? I havnt seen the pistons on the scale yet so I cant say for sure its that off, but I called my rotating kit supplier and he said bullocks that not even eagle sends out these forged pistons that far off.
Oh, does it help I even got a balance sheet with my kit? I didnt understand what all the numbers ment, but perhaps if I posted them, would that help at all?
Old Apr 6, 2007 | 12:32 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It might be interesting to see what the numbers are.
3 grams is a bit much of a variation in weight. Something like less than 0.1 gram would be a much better.
Old Apr 6, 2007 | 06:56 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
@ 7000rpm 3 grams could easily make some rather expensive 'speed holes' in your block and fenders!
Take it up with the original supplier. Its their problem not yours if it was supposed to be pre-balanced...
Old Apr 6, 2007 | 09:29 PM
Car: 91 RS
Engine: 350 vortec
i should mention that just because the rods are balanced wouldnt mean the entire assembly is...
Old Apr 6, 2007 | 09:35 PM
7.0 camaro's Avatar
Car: camaro
Engine: 383
Transmission: 350 turbo
when i bought mine they took into account the rings, piston pins, pistons, rods it even came wit ha new dampener and flexplate. runs smooth to me. i built it myself. even had to grind the rods to clear the camshaft.
Old Apr 6, 2007 | 09:46 PM
Car: 91 RS
Engine: 350 vortec
they should have also balanced with the weight of the rod bearings...
if you had to grind the rods then it is no longer balanced.. as the rods are balanced end to end then the receprocating weight is balanced on the crank
Old Apr 6, 2007 | 09:55 PM
7.0 camaro's Avatar
Car: camaro
Engine: 383
i turn it 7500 every time i start it up. no problems here. it has hit 8000. not on purpose.
Old Apr 6, 2007 | 10:12 PM
Car: 91 RS
Engine: 350 vortec
i would say you got lucky.
Old Apr 6, 2007 | 10:47 PM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
I'd take it to another shop.
Old Apr 7, 2007 | 12:31 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
take it to another shop? what particular reason?
Old Apr 7, 2007 | 10:31 AM
Car: 91 RS
Engine: 350 vortec
to see if the current shop is trying to take your money.
Old Apr 7, 2007 | 12:48 PM
Guest
Guest
Posts: n/a
Or find someone with a scale. 3 grams difference in piston weight should be easy to find... if its there. Thats something you can verify without any special tools aside of a scale.
Almost sounds to me like the seller of the kit buys some parts that are 'matched' from the manufacturer and calls them balanced. Thats not always true, for more reasons than one. Sometimes its a +/-1 gram tolerance (so they can be off as much as 2), and like what happened to me... got a set of pistons and for whatever reason, 2 were not part of the matched set. I ended up having to return them.
Old Apr 7, 2007 | 01:03 PM
Damon's Avatar
Spending $20 on a digital postal scale that can read in grams is a handy thing to have. I always check the pistons and rods myself before taking them to a shop- just to make sure things are "roughly right" before they go off for expensive machine work. I do a lot of stuff where I'm playing mix-n-match with different parts so doing my own home double-check sometimes turns up stuff that is obviously out of whack.
Old Apr 7, 2007 | 01:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I think so, too. They're probably buying a set from the manufacturer and assuming they're already weight matched. Then they take one piece at random and use it to calculate the bob weights for balancing.
midge54
Dec 27, 2019 04:14 PM
italiano67
Dec 11, 2016 09:21 AM
LT1Formula
Nov 16, 2015 01:13 PM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
