World vs. Dart
Old Apr 7, 2007 | 07:13 PM
Midnyte81's Avatar
Car: 1984 Z-28
Engine: 350(bored 0.060)
Transmission: Probuilt TH700-r4 tranny with the w
Axle/Gears: 10 bolt 7.5" posi 3.42
World vs. Dart
I'm out here asking the one question no one has answered. Which cast-iron head is better, World Sportsman II, or the Platinum Iron Eagle. Let me say first of all that if you look at earlier posts by my name, I had in my possession a set of old Dart High port aluminum heads. Well, the heads are no more and I have a brand new set of World Sportsman II heads (200cfm Intake). What I want to know is that if I had a set of Dart and World heads (The ones mentioned above with the 200cfm Intake) and did a comparison, which ones would make more horsepower and torque between idle and 6000 rpm on a plain Jane Chevy 350? Any takers?
Old Apr 7, 2007 | 07:56 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: World vs. Dart
If there was any difference in performance, you'd probably not notice it.
Old Apr 7, 2007 | 08:46 PM
Midnyte81's Avatar
Car: 1984 Z-28
Re: World vs. Dart
Good. I was just making sure the money spent on these heads were spent well. Also, other than never having to change another timing chain again, what are the benefits of upgrading to a gear drive?
Old Apr 7, 2007 | 09:08 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: World vs. Dart
lots of noise depending on what one you get... but they all will make noise
Old Apr 7, 2007 | 09:37 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: World vs. Dart
More accurate cam timing since gears dont stretch too well!
Old Apr 7, 2007 | 10:29 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Re: World vs. Dart
Their the same company
Old Apr 7, 2007 | 10:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Well, they used to be, but they aren't any longer.
Old Apr 8, 2007 | 01:05 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: World vs. Dart
The Dart Iron Eagle Platinum heads will make more power in stock form. They flow more air. The World Sportsman II heads need a little porting to flow the same as the Dart heads do.
The Sportsman ports are plenty big enough but the big nasty valve guide boss down in the bowl needs slimming, trimming and contouring. Then a general overall port clean up and smoothing will get the job done. Then you'll be ready to rock.
Don't worry, the Sportsmans are a good head.
They just need a little more preperation.
These heads weree designed and intended to be ported and cleaned up by the end user.
Old Apr 8, 2007 | 02:31 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: World vs. Dart
The Dart 200cc and World 200CC are very similar heads, not the same, but very very similar, because they are both based on the "Dart Sportsman II" heads they made back in the day together. After they split up, neither one owned the rights to that head, so they just made their own "new" heads based off that design. I doubt you'd notice any real difference between the two.
Old Apr 8, 2007 | 04:57 AM
Midnyte81's Avatar
Car: 1984 Z-28
Re: World vs. Dart
Thanks everyone. I have the Summit noisy gear set. I have heard Dart and World were the same a while back, and that they had a Dart II head. For some reason (Price difference of 250 dollars), I was leaning more for the World heads. I can't be disappointed since this is a daily driver and never a drag car.
Old Apr 8, 2007 | 09:58 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: World vs. Dart
I had a noisy gear set in my car for 1 day. Even I thought it was too noisy.
Old Apr 9, 2007 | 01:25 PM
Air_Adam's Avatar
Re: World vs. Dart
I have the old Dart II heads, although I haven't installed them yet. The basic design of the chambers looks very similar to both the World Sportsman heads and Dart IE heads.
Old Apr 9, 2007 | 03:12 PM
five7kid's Avatar
Re: World vs. Dart
Originally Posted by Midnyte81
... I have a brand new set of World Sportsman II heads (200cfm Intake).
Good heads. Usually benefit from some pocket clean-up. Their name appropriately is World "Castings", not World "Finish Machining".
Old Apr 9, 2007 | 03:28 PM
Slayre's Avatar
Re: World vs. Dart
I dont know how true it is but I have heard the gear drive will cost you about 7 HP over timing chain.
gt4373
Oct 8, 2015 10:37 AM
Damon
Sep 26, 2015 04:29 PM
-=Z28=-
Sep 24, 2015 10:21 AM
3.8TransAM
Sep 17, 2015 02:16 PM
scottmoyer
Sep 7, 2015 07:06 PM
