fuel dripping from injectors
Old Apr 8, 2007 | 06:42 PM
gcmcmahan's Avatar
i have a 83 trans am crossfire injection .car will not start.only dripping from injectors.i checked fuel pump and pump does hum when key is in on postion.what else could this be?
Old Apr 8, 2007 | 06:43 PM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
Re: fuel dripping from injectors
Need more information but it could be the fuel pressure regulator.
Old Apr 9, 2007 | 08:02 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Need more info.
But fuel should not be dripping, period, from the injectors.
Old Apr 14, 2007 | 12:02 AM
gcmcmahan's Avatar
when i crank eng there is no spray from injectors they just drip fuel,if this is fuel regulator how would i check this
Old Apr 14, 2007 | 08:55 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
First check your fuel pressure. Not sure what you should have on a crossfire.
Old Apr 14, 2007 | 04:53 PM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
The 82 Cross Fire engine had a normal fuel pressure of 9 - 13 psi. The 83 engine should have the same values.
There are three pages for the diagnostics for the Fuel Delivery System on the 82 Cross Fire. One sheet is the electrical schematic, one sheet checks out the electrical connectiions and signals to the TBI and the third sheet checks out the fuel flow to the TBI units. I will try and scan these and post them, but it will be a few days, as I have to work on my taxes first.
The regulator is internal to the injector body itself. If one or both are bad it might be a good idea to rebuild the TBIs, as you have to partly disasemble the unit anyway.
Dave
Old Apr 14, 2007 | 07:39 PM
gcmcmahan's Avatar
THANKS DAVE FOR THE INFO..
Old Apr 26, 2007 | 12:19 AM
GCMCMAHAN
I don't know if you figured out your problem yet, but I have scanned some trouble shooting charts from the 82 Camaro Service manual for the CrossFire engine. I suggest you right click on the image below and "Save AS" to your computer. Then open the file in some picture viewer software so you can rotate and zoom in to read them. This first image is Chart 4A which is general trouble shooting when the engine cranks but won't start. Your condition is on the right side of the chart. Charts 5A sheets 1 and two are also posted. Note that there will be a following message with the schematic diagram, so you can see the wiring and plumbing.
If you need expolded views of the TBIs let me know and I will scan them in. The manual also has the removal and installation of the injectors if you are interested.
Let us know if you get this problem fixed
Dave
Attached Thumbnails fuel dripping from injectors-82-camaro-50l-fuel   fuel dripping from injectors-82-camaro-50l-fuel   fuel dripping from injectors-82-camaro-50l-fuel
Old Apr 26, 2007 | 12:23 AM
And here is the schematic.......
Dave
Old May 4, 2007 | 08:52 AM
gcmcmahan's Avatar
dave
thanks for all your effort.
stalkier
Dec 6, 2015 11:25 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
Firechicken86
Aug 12, 2015 10:07 PM
