HIGH PERFORMANCE CAM
Old Apr 10, 2007 | 08:09 AM
tmw1's Avatar
I HAVE A 1990 FIREBIRD WITH 5.0 LITER THROTTLE BODY INJECTION, IF I INSTALL A HIGH PERFORMANCE CAMSHAFT, WILL I HAVE TO REPROGRAM THE ECM TO TAKE ADVANTAGE OF IT?
Old Apr 10, 2007 | 10:05 AM
StreetRod's Avatar
Car: 89 Supra
Engine: Tbi 350
Re: HIGH PERFORMANCE CAM
Yes, search around and you will find what u need.
Old Apr 10, 2007 | 10:34 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Not if you do it wisely, I can tell you how to get 250 HP/340 TQ without touching the computer. I have done it a couple of times now on L03 TBI trucks that had factory roller cams.
You have your stock TBI 305 truck engine that makes 180 HP/265 TQ.
1 5/8" primary tube headers, 3" collectors, into dual 2 1/2" pipes, Y'd into a single 3" cat and 3" muffler.
Stock heads at the stock compression ratio
1996-2002 Vortec 305/350 truck roller camshaft, it is much improved over the peaunut cam and has a narrower Lobe seperation angle than the LT1 cam does.
1.6:1 roller rockers"
Stock intake manifold with a 1" tall open center spacer
Ultimate TBI moded TBI unit, set the fuel pressure at 14 psi
Set the timing at 6*
If you have an automatic get one of the B&M or Transgo governor recalibration kits and setup the WOT shift to give you 5,000 rpm shifts.
In my experience, automatic TBI 305 trucks will dyno right at 200 RWHP/290 RWTQ with these modifications.
Old Apr 10, 2007 | 06:12 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Thats alot of pissing around for 20hp/25tq...
With a PROPER ECM TUNE it should pull better numbers though...
Old Apr 10, 2007 | 07:02 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
That is 70HP/65TQ without touching the tuning.
Old Apr 10, 2007 | 07:08 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
You ended your post with " In my experience, automatic TBI 305 trucks will dyno right at 200 RWHP/290 RWTQ with these modifications"
Tell me how a TBI truck motor will make 50hp/50tq less than the same motor in a car...?
Old Apr 11, 2007 | 09:01 AM
WhiteHawk's Avatar
Car: 1991 Firebird
Engine: 350,Dart Heads,Weiand In,Roller Cam
Transmission: 2400-Stall, 700R4 w/ Kit
Axle/Gears: 4th Gen 3.42 disc (I wish)
Call comp cams or crane cams techline.....Tell them what you have and they will recommend the best cam for what you have and even tell you if you need to modify the computer. Research your engine a little, like the induction system, valve sizes, if you have an exhaust....
You are the textbook n00b (not meant as a put down), the hole goes deeper then you think.
Old Apr 11, 2007 | 07:09 PM
ljnowell's Avatar
I believe he is saying they will get the 250 at the wheels, which would be 70 more than the 180 it was rated at the flywheel stock. still seems like a lot of work for a little gain though.
Old Apr 12, 2007 | 06:04 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Yes, i see it was edited now to say RW #'s
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
beastin91rs
Oct 9, 2015 07:38 AM
gta90
Sep 15, 2015 04:00 PM
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
