oil sending unit
Old Apr 11, 2007 | 09:51 AM
88ttopta's Avatar
oil sending unit
i just bought a new oil sending unit for my 305 tbi. the guy said the unit is located on the intake manifold but i can't seem to find it. the haynes manual isn't much help in this area either. any info would be great. thanks. chris.
Old Apr 11, 2007 | 10:01 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: oil sending unit
I have an 84 z28 and mine is located on the drivers side right behind the intake manifold. I believe yours should be in the same place.
Old Apr 11, 2007 | 10:05 AM
j dezzy's Avatar
Car: 87 TA
yup
Old Apr 11, 2007 | 10:14 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
my 89 305 TBI Bird was on the left side by the oil filter.
Old Apr 11, 2007 | 10:20 AM
88ttopta's Avatar
mine is a 88 ta. i just looked on the right and still didnt see anything. do you have to access it from under the car or from the top.
Old Apr 11, 2007 | 10:28 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Well there are to locations for the sending unit. 1 and I believe the most common is on the driver side on top of the motor right behind the intake manifold. 2 is right above the oil filter .
Old Apr 11, 2007 | 10:29 AM
j dezzy's Avatar
Car: 87 TA
my 84 TA has it behind the intake. and my 87 camaro had it above the oil filter. those are the only 2 I've seen too.
Old Apr 11, 2007 | 12:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
In general, EFI models (TBI, TPI) will have the oil pressure sending unit/oil pressure switch combo above the oil filter.
Carb'd engines will have the oil pressure sending unit behind the intake manifold.
Old Apr 11, 2007 | 02:44 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
E4ME engines have the switch at the oil filter also, pretty much any 1980 and up carb engine, i dont think ive ever seen anything '80 and up without it, two spade connector,
good luck
Old Apr 11, 2007 | 03:14 PM
five7kid's Avatar
Only if it had the in-tank electric pump, which was only standard on the '87 model year.
My '86 doesn't have it above the oil filter.
Old Apr 11, 2007 | 08:35 PM
Silver87's Avatar
Car: 87 T/A
Engine: 305 4BBL
Transmission: 700R
My 87 has it behind the distributor and way down there sticking up on a stem with another oil pressure sensor on it. It's way back there. It only took a small wrench and a few minutes to change mine. Mine was a large silver can with a spade terminal. It is for the oil pressure gauge. The small one I think is for the light.
Old Apr 11, 2007 | 09:11 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
1989 Firebird 305 TBI L03 vin code E
Old Apr 11, 2007 | 10:56 PM
88ttopta's Avatar
thanks for the attachment. that picture says it all. thank. chris
Old Apr 11, 2007 | 11:00 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
that guy is a retard.. but anyway, looks like you got this solved
Hotrodboba400
Dec 10, 2019 07:07 PM
Gunsbee
Sep 7, 2015 07:10 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
