2 bolt 350
Old Apr 11, 2007 | 02:29 PM
pookey_03's Avatar
2 bolt 350
I need a 2 bolt main 350 for my 1986 iroc. i was wondering if anyone knew a good place to find one. i want a new one that will bolt up in my 86 without any motor mount work. any help would be awesome. thanks guys...
Old Apr 11, 2007 | 02:34 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: 2 bolt 350
Any 350 will bolt right up. Are you looking for a short block or long block ?
Old Apr 11, 2007 | 10:48 PM
pookey_03's Avatar
Re: 2 bolt 350
well im looking for a short block, i just need to know a good place to find a 350 short block assembly, thats a 2 bolt main for about $1,500.
Old Apr 11, 2007 | 10:51 PM
80smetalfan's Avatar
Car: 1989 IROC
Engine: LB9
Axle/Gears: 3.42 Posi
Re: 2 bolt 350
Do you want a new/rebuilt block, or will a used one work?
Old Apr 11, 2007 | 10:54 PM
pookey_03's Avatar
Re: 2 bolt 350
im looking for a new one but a used one will work.
Old Apr 11, 2007 | 11:00 PM
Car: 1989 IROC
Engine: LB9
Re: 2 bolt 350
There are listings on this board for used parts, you'll see a lot of 350s and 355s on there.
www.craigslist.com might have something more local for you, depending on where you live. Usually used.
There are a whole host of aftermarket companies that offer new shortblocks and longblocks. Summit, Jeg's and GMPP are a few, off the top of my head, that have websites and whatnot that you can check out.
Old Apr 12, 2007 | 07:29 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Re: 2 bolt 350
http://www.gmperformanceparts.com/Pa...l.jsp?engine=0
Old Apr 12, 2007 | 10:26 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
http://www.sdparts.com/product/12556...eAssembly.aspx
Old Apr 13, 2007 | 02:04 PM
pookey_03's Avatar
Re: 2 bolt 350
i need a 2 bolt main tho
Old Apr 13, 2007 | 02:10 PM
AmorgetRS's Avatar
Re: 2 bolt 350
Why do you need a 2 bolt? Or do you mean 2 piece rear main seal?
Old Apr 13, 2007 | 02:15 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: 2 bolt 350
I have a 2 bolt main, late model 1 piece main, balanced, forged, 363 stroker, complete short block. Also have a used complete 4 bolt 350 on an engine stand. PM if interested.
Old Apr 13, 2007 | 02:23 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 2 bolt 350
4 bolt mains (stock style) are usually thought of as being superior to 2 bolts, at least to the average garage Joe. Unless you're thinking of drilling for angled 4 bolts later, in which case you'd probably want to custom build your short block with the right forged pistons and all that from the start...
Old Apr 13, 2007 | 03:57 PM
five7kid's Avatar
There is no such thing as "needing" a 2 bolt main, unless you plan on replacing the main caps with splayed 4-bolt main caps. And, unless you're planning some serious power, there is no need to plan on that.
Old Apr 13, 2007 | 08:34 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: 2 bolt 350
Guys, I think he's just looking for a reman engine. Like THIS.
Edit: oops. that's a 305. but you get what I mean....
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
camaro71633
Sep 1, 2015 10:24 AM
theurge
Aug 21, 2015 12:46 PM
