power steering problem
Old Apr 11, 2007 | 03:59 PM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
i need to know where to buy the high side line that goes from a type two pump to the box it only needs to be like a foot long
these are the fittings i need
Old Apr 11, 2007 | 04:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: power steering problem
Any parts store should have a stock hose.
Old Apr 11, 2007 | 04:52 PM
z28z34man's Avatar
it is not a stock pump and it is not in the stock location
the bigger one that goes in the box is an 18 mm i got that from searching
the smaller one is a 5/8 wrench size
Old Apr 11, 2007 | 05:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Try the yellow pages under "Hydraulics" then to get a custom hose made.
Old Apr 12, 2007 | 11:39 AM
z28z34man's Avatar
i called all the places in town no one can make a hose with o ring fittings on the ends but i think i may have found the solution
for the box
http://www.performancebodies.com/sto...pf%5Fid=101230
for the pump because 16 mm and 5/8 are almost the same size
http://www.performancebodies.com/sto...pf%5Fid=101220
Old Apr 12, 2007 | 11:43 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They're called "Saginaw" fittings... Earl's makes adapters to use AN fittings with them.
Old Apr 12, 2007 | 11:51 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Russel's and earls both make adapters for that fitting to AN fittings.
then have a regular AN hose made to fit.
This is similar to what you need.
http://store.summitracing.com/partde...5&autoview=sku
You all beat me to it.
Old Apr 12, 2007 | 01:06 PM
z28z34man's Avatar
is the o ring needed on the pump side or can i use this
Old Apr 12, 2007 | 01:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That fitting is an inverted flare. It's a different beast entirely. You need the O ring.
Old Apr 13, 2007 | 10:03 AM
z28z34man's Avatar
the pump is a profile pump would anyone know what size fitting it is.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
db057
Aug 22, 2015 08:17 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
