valave springs that will hold .512" lift and fit stock heads???
Old Apr 16, 2007 | 04:47 PM
wannafbody's Avatar
Car: 88 GTA
Axle/Gears: 3.27 9bolt
I am looking for some springs that will fit the stock heads My lift will be .512" so Im guesseing they need to be good for about .530"??
ALso would screw in studs be needed?
thanks I really need these!!!
Old Apr 16, 2007 | 05:04 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: valave springs that will hold .512" lift and fit stock heads???
Pinned studs, or screw in studs are a very good idea for any aftermarket springs.
Comps 981's would work for that. Any of your basic 1.25" performance spring will work fine. Comp's 981's are the part # that i've memorized that's all.
You'll probably want to machine down the guide boss, and set it up for positive valve seals.
Old Apr 16, 2007 | 06:14 PM
wannafbody's Avatar
Car: 88 GTA
i didnt machine the bosses down and still ran the positive , I actually already have teh comp 981's, i have not found anywere that tell the recomended max lift for them, but I think I read .500" somewere. I am not sure.
Is there anyway to find out?
Old Apr 16, 2007 | 08:19 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
stock heads won't have the retainer to guide clearance for that lift.
Old Apr 16, 2007 | 09:24 PM
wannafbody's Avatar
Car: 88 GTA
what is the max lift that will work? I might just have to downgrade to 1.5 rockers
Old Apr 17, 2007 | 12:22 AM
xpndbl3's Avatar
Car: 1984 Z28
.450-.480 depending, you have to check each head individually to find out.
Old Apr 17, 2007 | 12:25 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
.480" is the generally accepted "area" where lift becomes an issue in terms of the bottom of the retainer hitting the top of the guide boss. However, only a physical mock up and measurement can tell for certain.
I've run Isky's 235-D spring at the suggested installed height of 1.750" with no problems before. They're good to .550" lift. (.600" difference between the installed height and coil binding height, subtracting .050" as a 'safety' clearance).
Old Apr 17, 2007 | 07:24 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If you want to run .512" lift using the comp 981 springs you would want to check and verify the spring installed height.
if it is 1.71" or more you'll be fine. If it is less than 1.71" you won't be fine. Then you need to check the amount of space you have between the top of the valve seal and the bottom of the valve ratainer. Should be a minimum of .512"+.050" or .562". If it is less than this you won't be fine.
You need to remove a valve spring and check these specs by measuring them yourself before running the motor.
Generally, on stock heads; if they were just machined for guide seals without shortening them you will not have enough room for .512" valve lift.
Old Apr 17, 2007 | 07:43 PM
wannafbody's Avatar
Car: 88 GTA
well looks like im gonan pass on a cam swap...
I need some heads
Old Apr 17, 2007 | 10:52 PM
F-BIRD'88's Avatar
What cam are you tring to use?
Old Apr 17, 2007 | 11:14 PM
wannafbody's Avatar
Car: 88 GTA
http://store.summitracing.com/partde...8&autoview=sku
I was looking at that one, I guess I could use it if I bought 1.5 rockers but I just bought some 1.6 RR's.
Id like a fairly choppy idle thuogh, I really want a Lt4 hotcam but im thinking its to big, but if I have to get heads anyways................ then why not
Old Apr 17, 2007 | 11:21 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
hey dont mean to hijack just wanted to get f-bird's attention
if you have heads with positive seals can the guides be cut down for a cam with lifts over .512 and still retain the positive seal?
Old Apr 17, 2007 | 11:34 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Yes. Oh, I'm not F-Bird. Oops.
Old Apr 18, 2007 | 03:37 PM
F-BIRD'88's Avatar
yes you can. The gudie boss cutter cuts down the whole step that the seal sits on. just lowers the whole thing.
That comp cam will not have a choppy idle.
Old Apr 18, 2007 | 04:26 PM
wannafbody's Avatar
Car: 88 GTA
will the hotcam?
Old Apr 19, 2007 | 05:23 AM
Pat Hall's Avatar
Just took a look at the specs on the cam you posted the link to. If you switched back to 1.5 rockers, you'd probably be just fine running it, especially since you already have 981 springs. As for the idle quality, it'll probably be nice and smooth. That cam is nowhere near radical enough to give you a rough or choppy idle. On the other hand, the LT4 hot cam would definitely require some machine work to assure retainer to guide clearance.
Old Apr 19, 2007 | 06:50 AM
wannafbody's Avatar
Car: 88 GTA
Ill just have to wait and get some good used heads then. How will I know if aftermarket heads will even work with say .575" lift?
Old Apr 19, 2007 | 12:49 PM
F-BIRD'88's Avatar
If your motor has the GM TPI fuel injection system you need to rethink what you are trying to do. A "rough idle" cam will not work . It will play havic with the EFI ( low manifold vacuum) and will not enhance the tuning effect of the long runner tuned port manifold.
Old Apr 19, 2007 | 01:16 PM
wannafbody's Avatar
Car: 88 GTA
i have heard the Lt4 hotcam on some Lt1's and it sounds great. Is that to much cam for the stock ECM? will I still be able to tune it?
I will be running a Lt1 intake or a stealth ram.
Old Apr 19, 2007 | 01:32 PM
F-BIRD'88's Avatar
As far as power is concerned the LT4 hot cam will work very well with the HSR or a LT-1 manifold. You'll have to ask some one that is more into EFI as to how best to tune it. it can be done and will need some dialing in. I'm an old Carb guy so can't really help ya with that.
Jeremys87
Jul 14, 2022 09:08 PM
customblackbird
Aug 15, 2021 10:16 PM
theshackle
Mar 5, 2017 06:37 PM
sailtexas186548
Aug 26, 2015 03:32 PM
anesthes
Aug 8, 2015 09:37 PM
