will these work?
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
will these work?
will these springs fit? i have a 350 crate motor i believe it is a pre 86 block and heads, not sure of the number on the heads, they are the smog heads. here is the link.
http://store.summitracing.com/partde...+&autoview=sku
Re: will these work?
Those are pretty much their entry-level, stock-diameter spring for SBC.
Yes they will "fit".
"Work" is another matter altogether. That depends on what else they have to "work" with.
You would need the retainers that go with them, and probably some shims, and new seals and keepers.
Terrell351
Jun 13, 2021 01:13 PM
