3 quarts of oil a day?!?!?!?!!?
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Yeah so my car is using 3 quarts of oil a day! I parked it and let it idle for about 10 minutes, there was no oil on the pavement and it does not smoke out of the exhaust!?!?
Where the hell is my oil going?
Bad rings?
Bad valves?
I forgot to mention that it does smoke from the engine compartment quite a bit! Mostly out of the mating surface of the exhaust manifolds! But there is like hardly any smoke that comes out of the end of the exhaust system?
Bad rings?
Bad valves?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 3 quarts of oil a day?!?!?!?!!?
Rad?
Sounds like it's going out the tailpipe though.
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
The only time it smokes out the tailpipe is when it starts up!
It also starts smoking out of the mating surface of the exhuast manifold as soon as it starts up, it doesn't even have to reach operating temperature!?!?!?
Car: '82 Z28
Sounds like oil is coming from the valve covers running onto the manifolds.
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
3 quarts of oil can come out of the valve covers in one day?!?!
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
you have to have a leak somewhere else.. but i would def. check those valve covers.. if tightening them doesnt help the problem, time to change gaskets..
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
how would the smog pump affect oil loss?
Car: 1987 Firebird
Engine: 355
smog pump wouldnt effect it, but it may help nnarrow down what were seeing. Also, if oil is dripping onto the manifolds, it wont be a lil bit of smoke, it will be a TON!!! Like a thick black cloud will rise up out of your hood unless your moving 40+ miles an hour. I punctured my nylon oil pressure line, and a steady stream about as thick as a hair was being sprinkled on my driver's manifold, it was so little that the manifolds were smoking it completely, but the second i stopped, a thick black cloud rose up out of the hood. (and the hood was closed)
Also, this is a incredibly big fire hazzard. I think the smoke ritter is describing is incomplete combustion, so you probably have oil leaking into the cylinders. Its wierd that it wouldnt come out the tail pipe, but you car can eat up alot of oil that way.
That's what everybody thinks!!!
They're WRONG. It's actually the single most common new-motor, or modded-motor, or just hacked-on motor, mystery oil leak. The top bolt that used to hold on the bracket, goes RIGHT DIRECTLY INTO the crankcase. Look in that hole and you see the fuel pump drive rod. It won't leak a drop when you just sit there, but when driving down the road, it will SPEW.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
