Throttle Return Spring - Mr Gasket MRG-19 - Where To Mount?
Old Apr 22, 2007 | 09:15 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
I picked up Mr Gasket MRG-19 Dual Throttle Return Spring and Bracket Kit. This will sound stupid but i have no idea where the best place is to mount it. It says on the intake manifold. But the bolt hole on the bracket is not big enough for a bolt that would go into the intake manifold. I can modify it easily, but just wondering if anyone else has this setup or where did they mount their's?
Old Apr 23, 2007 | 02:02 AM
Pat Hall's Avatar
Re: Throttle Return Spring - Mr Gasket MRG-19 - Where To Mount?
If it's on the car you have the Edelbrock intake on, just use one of the coil bracket mounting holes. They're only used when you're running an old school points ignition w/external coil anyways, so they're shouldn't be anything stopping you from using one of them. I hooked up dual return springs to my Weiand X-Celerator/Holley 650 DP setup, and that's where I bolted the bracket to on mine. Should be a 5/16 thread size, so the bolt will go right through that hole in the bracket without having to make it bigger.
Old Apr 23, 2007 | 07:48 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
im running the edelbrock rpm air gap, ill look for the extra 5/16 thread size. is it in front?
Old Apr 23, 2007 | 08:50 AM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
On the back of the manifold right in front of the distributor, driver's side.
Old Apr 23, 2007 | 03:13 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
thanks guys, but i just mounted it on the thermostat. there needs to be tension on the throttle or it wont come back so it had to be in front of the intake and i couldnt find no place except for thermostat.
Old Apr 24, 2007 | 12:20 AM
Pat Hall's Avatar
When I get a chance, I'll snap a pic of how I got mine rigged up. It provides plenty of tension to pull the throttle back, and it looks a lot cleaner. I used to have mine mounted to the t-stat housing bolt too, and I never liked how it looked.
Old Apr 24, 2007 | 02:39 AM
Pat Hall's Avatar
Here's the pics of mine. Since the spring is hooked to the very bottom of the throttle arm, it pulls it all the way closed easily.
Old Apr 24, 2007 | 11:12 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
thanks alot for the pics i think ill change mine to back there as well...
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
