roller cam recommendation for a 350
putting together a late moel 350 with flat tops and vortec heads and carbureted and want a good performing roller cam.the heads are rebuilt to stock.i picked up a ramjet/ht383 gm cam and lift is 431/451.im being told that cam is a little too small.any ideas?any good gm cams under 500 lift?thanks
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Re: roller cam recommendation for a 350
Do yourself a favor and have the valve guides and the spring seats cut for bigger springs and more lift. Stock they are only good for around .480 lift.
The comp xr276hr or xr282hr cam would work well with those heads. If you have the head work done. Add a Performer RPM airgap and you should have a strong street car.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Agreed, the xr276hr is a pretty common setup. With those flat tops, vortecs, carb and performer RPM = a well matched combo. A proven 375ish HP combo right there.
what kind of money can i expect to spend to have the heads machined.i cant complain much,the shop i used only charged me $78 to do a stock rebuild on the heads.
Car: Camaro
Engine: Carbed L98
Transmission: TH350
You do need to match the springs with the cam you choose. So depends on the price of the springs/retainers. Comp suggests there 986 or 987 springs for the xr282hr cam. You can check Summit or Jegs for the price of the springs.
junkcltr
Aug 2, 2019 11:12 PM
ambainb
Apr 25, 2016 09:21 PM
MoJoe
Sep 24, 2015 09:12 PM
