speedo stopped working
Old Apr 24, 2007 | 06:22 PM
Zebulonsv8's Avatar
Hey my dad asked me to ask u guys this...
he has a 82 trans am and when he is going slow.. the speedo bounces alittle. but when he gets going very fast it just stops moving all together
but it used 2 work just fine... what could be th problem??
thanks
Old Apr 25, 2007 | 07:56 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Re: speedo stopped working
First of all. The 82 has a cable driven Speedo. If you have Cruise control then the cable goes through a transducer attached to the front part of the Driver side fender. It looks like this: It probably needs replaced. It also might need new speedo cables.
Old Apr 26, 2007 | 01:11 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
I have an 82 Camaro and I had a similar problem a long time ago ( I am the original owner). There are plastic drive pins on the ends of ths speedo cable at the cruise control transducer and one of mine finally broke.
Any way in the photo above on the left side, the top threaded connection is for the cable from the crusie control to the speedo on the clusteer. The bottom threaded connection is for the cable to the transmission.
If you do not have crusie control, the cable runs directly from the transmission to the engine side of the firewall, up the firewall and then through the firewall to the speedo.
Dave
Jorlain
Aug 24, 2022 05:11 PM
Wade787b
Sep 29, 2015 01:15 PM
Irocohio
Aug 12, 2015 08:03 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
beachrodder
Aug 7, 2015 04:27 PM
